EGR system Incomplete / Secondary Air Incomplete
Old Jun 12, 2012 | 05:20 AM
bennuss's Avatar
I have an inspection coming up and my computer gives not ready for emission testing due to EGR system Incomplete / Secondary Air Incomplete. I did the sequence recommended by nissan to get it to reset but it did not work. I have no light on and the car runs fine. Any suggestions?
Old Jun 12, 2012 | 06:40 AM
TunerMaxima3000's Avatar
Sounds like you're tryign to check your EGR system with a standard tester, if I were to guess.
You can't check that with just any tester. Sounds like a message because the tester isn't compatible with the Emissions system on the Maxima.
And if your engine light is off and there's no hidden codes with an OBDII scan, you should be just fine.
Old Jun 12, 2012 | 07:16 AM
bennuss's Avatar
I was using the software palmer scanxl. Thanks for your response.
Old Jun 12, 2012 | 07:35 AM
Yeah that won't do EGR diagnostics.
Old Jun 21, 2012 | 05:57 AM
bennuss's Avatar
It picks up the egr system on a toyota and a buick. What software does egr testing?
I was wondering if there is any software or list that compares the values that are pulled to what would be optimal?
Old Jun 21, 2012 | 06:48 AM
It will recognize the system but can't do computer diagnostics. You probably need consult II or one of the nissan ghost scanners. I don't know much about it.
I always follow FSM procedures and diagnostics with generic tools
http://nicoclub.com/fsm
Old Jun 21, 2012 | 09:02 AM
sontakke's Avatar
I believe you are talking about the IM status i.e. inspection monitors. How many monitors are ready and how many monitors are incomplete? What year is your car? For 2000 and before you can have up to two incomplete and still pass the emissions.
Maxima does NOT have secondary air. It should be NA i.e. not applicable.
Old Jun 21, 2012 | 11:38 AM
bennuss's Avatar
It is an 01 20th anniversary edition everything shows ready except secondary air heated catalyst and egr.
Also it does not seem to be getting any data from the o2 sensors
shilov
Feb 19, 2024 09:40 PM
DJLAX152
May 4, 2021 11:46 AM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
bumpypickle
Sep 20, 2015 08:22 AM
