Does this mean I need a new MAF sensor?
Old Jun 27, 2012 | 06:17 PM
gavin68's Avatar
I recently got the code P1320 (anyone know what this means? It's not in my scanner's manual for generic error codes). Today, I pulled out all of my ignition coils, cleaned them off, and reinserted them. I noticed an instant increase in performance, but now the engine makes a slight hissing sound every time I press the accelerator. Plus, it is now giving the error code P0174. Could this mean I need a replacement MAF sensor? I recently tried cleaning it with MAF cleaner, but that doesn't seem to have helped... maybe I even damaged it somehow?
Also, does anyone know what kind of tool to use to unscrew the screws for the MAF sensor? They appear to be a star-shape with a hole in the middle.
Old Jun 27, 2012 | 08:08 PM
Chris Gregg's Avatar
Get Off My Lawn
You can a set at autozone for roughly $10.
Old Jun 27, 2012 | 08:34 PM
DennisMik's Avatar
P1320 is "Ignition Signal". From the FSM:
Malfunction is detected when the ignition signal in the primary circuit is not sent to ECM during engine cranking or running.
Possible Causes
* Harness or connectors (The ignition primary circuit is open or shorted.)
* Power transistor unit built into ignition coil
* Condenser
* Crankshaft position sensor (REF)
* Crankshaft position sensor (REF) circuit
The P0174 is "FUEL INJECTION SYSTEM FUNCTION (LEAN) LEFT BANK".
Possible Causes:
* Intake air leaks
* Front heated oxygen sensor
* Injectors
* Exhaust gas leaks
* Incorrect fuel pressure
* Lack of fuel
* Mass air flow sensor
The left bank of the engine is the one by the radiator. The fact that you hear a hissing sound makes me think you have a vacuum hose disconnected.
The screws on the maf are Torx and the hole in the center is for security, so you need the Torx Security set. IIRC the maf screws are size T15.
If you need a FSM, you can download one from here:
http://boredmder.com/FSMs/Nissan/Maxima/
Old Jun 27, 2012 | 08:51 PM
gavin68's Avatar
Possible Causes
* Condenser
Possible Causes:
* Intake air leaks
* Injectors
* Exhaust gas leaks
* Lack of fuel
Thank you! I will certainly have another look tomorrow, especially for the origin of the hissing sound.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
