Car moves to side when accelerating
Old Jun 28, 2012 | 06:09 PM
jgosses's Avatar
My 2000 Maxima GLE will move to the right and sometimes to the left while accelerating particularily when the auto trans shifts. Its almost like the car will yaw when this occurs.
I recently replaced the front and rear motor mounts - the pass side mount was done about two years ago. Replacing the mounts, tightened the car up but did not correct the problem. Car has 220,000 miles on it.
Any ideas?
Jim G
Old Jun 28, 2012 | 06:33 PM
Craig_0530's Avatar
I choose not to comment.
Check your ball joints, control arms and tie rods.
Old Jun 28, 2012 | 06:42 PM
T_Behr904's Avatar
And check the steering rack.
Old Jun 28, 2012 | 07:32 PM
mrjamaica98mx's Avatar
i am having si,ilar problem plus grinding noise was told several problems (ball joint-sway bar bushing -left front cv axle-but im starting with rear engine mount my question is did your rear sensor have a wire ie sensor on it the ome i buy from autozone has no wires?
Old Jun 28, 2012 | 08:23 PM
Shift_A32B's Avatar
Old Jun 28, 2012 | 09:08 PM
03VQMAX's Avatar
Steering rack, worn struts, uneven tire wear, and whatever everyone else said
Old Jun 29, 2012 | 05:42 AM
Xpcgamer's Avatar
Torque Steer?
Old Jun 29, 2012 | 02:59 PM
Maxident's Avatar
220K is a lot of miles. The suspension bushings have to be very tired if you've never changed them (never mind the shocks & struts).
Old Jun 29, 2012 | 03:32 PM
ShocknAwe's Avatar
most likely steering rack issue and more specifically outer tie rod ends. Either that or your ball joints and CA bushings are worn to hell
Lakersallday24
Jun 16, 2019 01:35 AM
Dennis Twohy
Oct 1, 2015 06:01 PM
doobadoo
Aug 15, 2015 06:43 PM
erniel
Aug 8, 2015 09:32 AM
ZerotoSixty
Aug 6, 2015 04:34 AM
