00 - 03 muffler question
Old Jun 29, 2012 | 08:46 PM
gthirtymax's Avatar
Do 2000 through 2003 Maximas have the same muffler? Meaning you can use a 2003 muffler on a 2000, no matter if it's GXE/SE/GLE?????
Old Jun 29, 2012 | 09:39 PM
Rods03Max619's Avatar
Yes you can, they should fit 00-03, but I believe they are different in the 00-01 and 02-03 inside muffler design, but should bolt up the same....
Old Jun 29, 2012 | 09:52 PM
Chris Gregg's Avatar
Get Off My Lawn
+1
Only difference was that the 02-03 (maybe anniv Ed?) muffler had a nice juicy creamy center that added a few hp.
Or so they say. It has a flange that remains closed at low exhaust velocity and opens to another chamber at higher velocity to reduce restriction at higher rpms. But really, the entire exhaust is horribly restrictive. I don't suggest getting one new either. If you did, you could probably get a whole 2.5" catback system for cheaper.
Old Jun 29, 2012 | 09:55 PM
Get Off My Lawn
Just remembered. I've got a used 2003 muffler. But, it's just the muffler and piping without the flange. You would have to get a shop to weld it into place or install some new pipe on the end with a new flange to bolt it up.
Old Jun 30, 2012 | 07:17 AM
gthirtymax's Avatar
OK, thanks guys...
Old Jun 30, 2012 | 07:30 AM
T_Behr904's Avatar
To my knowledge they are all internally the same. They are made by Calsonic and have a flapper valve inside them that opens up at higher rpm. That's why at idle exhaust only comes out of one pipe. 00-01 had a stainless tip that wrapped around both pipes whereas the 02-03 did not. The 01 Anniversary had turndowns to clear the rear lip, and the I30 and I35's also have turndowns to clear the lower hanging bumper cover.
Old Jun 30, 2012 | 08:16 AM
Grand_hustle17's Avatar
^^^ that
Old Jun 30, 2012 | 08:37 AM
cjandura's Avatar
T_B sure does alot of research on things with holes in them
Old Jun 30, 2012 | 09:48 AM
OP shoot me a pm for a catback if you go that route
Old Jun 30, 2012 | 10:20 AM
T_Behr904's Avatar
Never can be too careful out there nowadays
Old Jun 30, 2012 | 10:31 AM
TunerMaxima3000's Avatar
Originally Posted by Chris Gregg
+1
This.
The 2000/2001 are different, but will bolt up fine. They don't have the valve inside.
The 2001 Anniversary Edition has the same style internals as the updated (2002/2003), this is the style that has a internal valve that allows a more 'open' design under higher flow conditions, this allows for a slight increase in power while maintaining quiet idle/cruise noise.
And externally the only difference is the tips as Tbehr said. The 2002/2003 looking much better, IMO.
All in all, you're best with a 2002/2003 version if you're looking for an OEM replacement.
Old Jul 1, 2012 | 04:47 PM
gthirtymax's Avatar
Hey TunerMaxima30000, I'm AARONHL on G35Driver
Old Jul 1, 2012 | 04:49 PM
gthirtymax's Avatar
Thanks for all the replies, I'm going to put a stock 02/03 muffler on my parent's 00 Max...luckily my friend has the muffler or me.
Old Jul 1, 2012 | 04:51 PM
T_Behr904's Avatar
Mine has the valve.
Old Jul 1, 2012 | 05:37 PM
Get Off My Lawn
But how do you REALLY know you do? How do ANY of us really know we do?
LOL!!
Old Jul 1, 2012 | 05:54 PM
T_Behr904's Avatar
LOL!!
It's quite easy to tell. When you're standing behind the car, exhaust at idle will come out of the right side pipe, as long as the valve hasn't been rusted out or stuck open. With the car running, put your hand behind the pipes and you can tell. If it's cold out, the condensation will also give it away.
Old Jul 1, 2012 | 05:59 PM
cjandura's Avatar
Mine has the valve.
LOL!!
Trust T_B he knows about Holes and Fapper Valves
Old Jul 1, 2012 | 07:15 PM
T_Behr904's Avatar
You got that right! Pass me a watermelon...
Old Jul 1, 2012 | 07:37 PM
ShocknAwe's Avatar
Old Jul 1, 2012 | 08:33 PM
Cool man so you have a Maxima as well or this is your rents?
Mine has the valve.
It's contrary to everything I know and have read about the 00 & 01, so unless yours has been replaced with an AE (2001) or an aftermarket one that has the valve....
But if you're correct and it was equipped that way from the factory, that's big news.
Old Jul 1, 2012 | 08:36 PM
gthirtymax's Avatar
I used to have a 96 and 98 Maxima a few years back before I bought the G35...my parents have had a 2000 Maxima since 1999.
Old Jul 1, 2012 | 09:03 PM
T_Behr904's Avatar
It seems like it's original to the car. The entire exhaust was all equally rusty and crusty. Last year, I had the B pipe flange where it meets at the rear section welded together with new pipe because it rusted out and broke. While I was at it, I had the resonator deleted and all new piping installed from the cat back to that joint. I also removed the stainless tailpipe wrap that went around both pipes since I didn't like the way it looked.
My car is also an SE, so perhaps the variable capacity muffler came with it, and the other models did not, perhaps...
I read about it being a variable capacity and sure enough, exhaust only comes out of one pipe at idle. When you rev it, exhaust then comes out of both pipes.
Here's an archive of a review from Motor Trend in July 1999 around the time the 2000 Maxima came out. In the article it says that it has a variable capacity muffler.
http://www.motortrend.com/roadtests/...e/viewall.html
Old Jul 1, 2012 | 09:07 PM
Get Off My Lawn
I say- I say... It was a joke, son.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
