Removed my BOP...
Old Jul 3, 2012 | 12:01 PM
Gizm0's Avatar
Removed my BOP...
The BOP had been on the car for over a year now, and I got used to the way the car felt with it. Loss of power/torque from 2000rpm to about 4000rpm, then a kick in the butt at 4000rpm all the way to the red line.
According the the FSM, the VIAS is opened from idle to 1800rpm, then closes from 1800rpm to 3600rpm, then opens up again until red line. Removing the VIAS creates an air flow disturbance between 1800rpm and 3600rpm, which is why the engine looses torque, then around 4000rpm, when the air flows better when both the upper and lower chambers of the intake manifold are opened to each other comes the kick in the butt.
Last week end, I decided to remove my BOP and put the VIAS back on the intake manifold, just to feel the difference. What I had in mind was keeping it like this for a week or two, then put the BOP back on...
However, I think I will leave the VIAS on... I forgot how smooth and well rounded the power band was with the VIAS... The high end gains of 2hp or 3hp are not worth the 10/15hp loss at mid range in my opinion. The way I drive my car, I'm most of the time below 4000rpm anyways, so keeping the VIAS on works better for me. If I was to go to the track, where I would keep the tach above 4500rpm, then I'd put the BOP back on... but for now, I love the way the smoothness and low/mid range torque feels, and hopefully, I can gain on my gas mileage too...
Not trying to hate on Aaron's BOP, it's a great product, proven to provide gains above 4000rpm, but whether it's for you or not depends on where you like your power.
Old Jul 3, 2012 | 12:04 PM
03VQMAX's Avatar
I'll be doing the same thing before I head out on my road trip, I think it eats more fuel as well.
Old Jul 3, 2012 | 12:06 PM
ShocknAwe's Avatar
Pretty much the BOP in a nutshell but not sure it needed a thread...
Old Jul 3, 2012 | 12:32 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Someone's shifting way too early
Old Jul 3, 2012 | 02:34 PM
Chris Gregg's Avatar
Get Off My Lawn
After all my bolt-ons (spacers, intake, full Cattman exhaust, fastcat, and Transgo hd2 kit) I've considered doing this as well. Particularly being an automatic.
As said, it's proven. But looking at my driving and where my rpm's run, I'm in agreement with swapping it out for the vias for a bit. Course, will test the system first to absolutely verify its working properly.
Old Jul 3, 2012 | 02:37 PM
aackshun's Avatar
+1
Old Jul 3, 2012 | 03:01 PM
T_Behr904's Avatar
Put the BOP back on and...
Old Jul 3, 2012 | 03:25 PM
NmexMAX's Avatar
dot dot dot ...
I couldn't go back even if I wanted to.
Old Jul 3, 2012 | 04:48 PM
Rods03Max619's Avatar
Me either, fell apart and the 2 little screws or bolts in the engine somewhere, thats what I think started my Oil Burner issue......
Old Jul 3, 2012 | 05:20 PM
Bad *** Newb
You'd hear it hammering if it was in there. They probably blew out the exhaust.
Old Jul 3, 2012 | 05:24 PM
Good to Know....
Old Jul 3, 2012 | 05:28 PM
Rochester's Avatar
That's the beauty of a fully reversible mod.
For me, it wasn't the few extra HP at the top end, it was the way the engine felt so smooth with the BOP. That whole VIAS kick... never liked it. Not one bit.
I think my VIAS is still in the attic somewhere, along with the OEM air intake. Hmm...
Old Jul 3, 2012 | 05:44 PM
Get Off My Lawn
Sounds like potential source of income for more vinyl mods.
Old Jul 3, 2012 | 05:47 PM
Grand_hustle17's Avatar
How you guys can tell what rpm you gain n lose 5hp is mind boggling lol...
Old Jul 3, 2012 | 05:53 PM
Get Off My Lawn
LOL!! I figure going on a diet and losing 100 pounds would net me the most gain.
Old Jul 3, 2012 | 06:06 PM
mrjasonlyrics's Avatar
You took off the BOP. Damn now you gotta replace it with a 5hp decal...
Old Jul 3, 2012 | 07:55 PM
T_Behr904's Avatar
Sounds like someone needs to get their butt-dyno recalibrated. PM Clashez...
Old Jul 4, 2012 | 06:32 PM
Xpcgamer's Avatar
Sorry. My Vias will never go back on. The 3.5 has enough torque on its own. I freaking love the kick in da balz when it swings past 4k. Thats when I know I need tires. The tires will lose traction after 4k when I need em.
Old Jul 4, 2012 | 07:14 PM
Old Jul 4, 2012 | 09:45 PM
TunerMaxima3000's Avatar
Even if they did that could still cause damage, that'd take out a precat without much trouble.
Loose precat crap could easily get sucked back into the engine and damage the rings.
IJS, possible.
Old Jul 4, 2012 | 10:45 PM
Bad *** Newb
IJS, possible.
True, but who still has cats....oh yeah
Old Aug 26, 2012 | 10:48 AM
Get Off My Lawn
Taking the initiative and verifying my vias worked (it did stick a little...fixed that) I re-installed it approximately 6 weeks ago. Wanted to do some consistent driving, monitor impressions, and get several fuel mileage readings.
Results: Yes, the power band felt smoother, but that was about it. I noted the car just continued to feel like it was pushing about the same up through redline. My fuel economy was overall unchanged and I could not determine I used any less throttle when driving/cruising.
Once I re-installed the block-off plate, made me grateful to have that little bit of extra kick up high for when passing.
Final Call: VIAS goes away perminently (For sale; PM me!). BOP here to stay. Really, any suprise?
Old Aug 26, 2012 | 12:50 PM
AznRyan's Avatar
Redlining like a pro
Old Aug 26, 2012 | 12:55 PM
I seen quite a few of these vids on youtube and I actually thought there was gonna be some boob action. LOL.
Old Aug 26, 2012 | 01:29 PM
AznRyan's Avatar
Lol, god bless lateral G-force!
Old Aug 26, 2012 | 01:33 PM
Yeah, its the thing that makes 99%click on the video .....
Old Aug 26, 2012 | 01:51 PM
Amen to that. It's funny because you see the driver is protected with helmet, gloves, fireproof racing suit with 3-point harness and there's a hot model half naked with no bra, little or no clothing on and gravity...
Old Aug 26, 2012 | 04:42 PM
zero2sixtyZ's Avatar
You embarrass me.
Originally Posted by nmexmax
i couldn't go back even if i wanted to.
+1. Ssim...
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
