WTF BRAKES!
Old Jul 14, 2012 | 04:14 PM
user name001's Avatar
WTF BRAKES!
hey all,
a few months back i replaced my rear pads because i was getting some squeaking noises, didnt fix my problem, last week i did my fronts and machined my rotors. didnt fix it, so now on top of the aqueaking that turns into kinda like a sand paper noise when even th smallest amount of break is applied im getting an aweful grinding noise thats more noticeable right befor i come to a stop. it seemed to start a week after doing the fronts so im pretty sure its coming from the fronts.. any ideas?
Old Jul 14, 2012 | 04:21 PM
L_U_D_I_AMaxima's Avatar
are the pads ceramic or organic?
Old Jul 14, 2012 | 04:25 PM
there mid priced raybestos so im assuming organic but not too sure.
Old Jul 14, 2012 | 04:28 PM
98maxi's Avatar
your splash shield may be a little bent and rubbing on the front rotors. It happened to me. The way to tell is to jack the car up and remove one front wheel at a time, look at the back of the rotor from the bottom of the wheel you removed and you will see a solid round mark on the rotor or rotors. Check both of the front wheels.
Old Jul 14, 2012 | 05:05 PM
dust shield isnt rubbing, brakes are seated properly.. i do notice that my rotors are kinda black, ive done lots of suspention swaps and brake jobs and never noticed brake rotors to be so black, i disnt cheap out on brakes but i also didnt get the best... i am now wondering if this noise im hearing is material transfer (brake material transferring to the rotors) would that cause the noise im exeriencing?
Old Jul 14, 2012 | 05:13 PM
djshwini's Avatar
I am experiencing the same thing and I read somewhere that the OEM rotors are the source of it. I am planning on replacing them with the 125 centric rotors. Hopefully that will solve the problem..
Old Jul 14, 2012 | 05:31 PM
well i guess ill throw some new rotors on her in a bit. 30 bucks a pop, i guess its worth it. i didnt pay to have my front rotors to be machined either so there is no real loss. its wierd how the grinding only started once they were machined though.
i did my rear pads that had 20% because of a squeal that was there and left the rotors, i did my front pads at 30% mind you the pads were litterally falling apart, and machined my rotors because they were a bit warped. i thought that had something to do with the squeal after doing the backs, but no luck still there. i guess new rotors all around and my pads should be ok still, correct? they are still in the 90% range or should i just throw on new pads and rotors?
Old Jul 14, 2012 | 06:16 PM
cjandura's Avatar
Sounds like the calipers are hanging on the pins pull them out and sand them a little then antisieze
Old Jul 16, 2012 | 10:53 AM
i will give this a try! thank you.
Old Jul 20, 2012 | 11:49 AM
I took the pads back and upgraded to the next best, anti seized the backings on the pads and the clips, so far problem solved, thanks for all the input guys!
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
