Metal grinding noise when I turn hard right
I bought my 01 SE AE about a month ago. Both front axels were replaced immediately before purchasing. Whenever I turn the wheel all the way to the right and move forward, I hear a loud metal, grinding noise. No other direction causes this noise. Any idea what this could be?
Thanks,
Rob
Thanks,
Rob
Have you put the car on jack stands and checked around? Shake the wheel left and right, up and down and see if there is any play. Turn the wheel all the way to the right and move the wheel by hand to see if the sound can be replicated.
Are there any other sounds just before it starts grinding? No popping noises?
I had the same issue a couple months ago when i had my ksport coilovers on. it turned out to be the Tie rod. not quite sure if it was inner or outer, but its probably what your experiencing with your car GL
trungg86
Sep 4, 2015 04:58 AM
