6 speed trans help
Old Aug 9, 2012 | 05:04 AM
95VQ30's Avatar
6 speed trans help
So my trans has not been catching gears under moderate to hard acceleration. Thinking it was a flywheel, I pulled the trans out and apart and discovered that the clutch and inside the bell housing was covered with a sludge or grease.
I am thinking there is a seal or O ring from the crank- it is the only area that can leak into the trans(that I can see). That crank has a little too much play and can jiggle more than I think it should.
The clutch was coated and ruined from this oil/grease/sludge that was almost "baked" on it like, with a consistancy of asphalt or tar.
Taking it to a trans shop today and will hopefully find the issue today or tomorrow.
Any ideas or has anyone else ever had this issue???
Edit- there has been a strange chatter sound from the trans for some months before- I am thinking it is the extra play, or wiggle, in the shaft coming out of the trans. And it would kick me out of 6th gear when I accelerated.
Old Aug 9, 2012 | 09:46 AM
cjones450's Avatar
Does it smell like oil or trans oil? could be your output shaft seal on the trans or your remain behind the flywheel
Old Aug 9, 2012 | 09:59 AM
95VQ30's Avatar
Thanks for giving an opinion...
No strong oil smell, it has a sludge consistency- I am hoping the seal failed- if not I may be trans shopping >.< I should know the status tonight or tomorrow morning.
Honestly after fixing this, I may sell the Max. It will be in top running condition with the mods and only some small cosmetic issues(dings, scratches, etc). I may need the money- So someone may get a great deal.
Old Aug 9, 2012 | 10:11 AM
ShocknAwe's Avatar
Can you check for tranny codes in a 5th gen? That looks a lot more like oil as opposed to tranny fluid. Should just be a seal and hopefully you caught it in time. I imagine it couldn't grab any gears at high speeds because that sludge would make it slip.
Old Aug 9, 2012 | 10:23 AM
Amerikaner83's Avatar
I thought the "trans fluid" in a manual WAS gear oil...
Old Aug 9, 2012 | 10:29 AM
ShocknAwe's Avatar
I think they call it gear lube technically. Either its terribly broken down or something else. Shouldnt sludge like that under any conditions really
Old Aug 9, 2012 | 12:29 PM
JonBlz's Avatar
a.k.a. STuNtMAN
i think it could be the rear main seal happened to me once years ago
Old Aug 9, 2012 | 01:06 PM
95VQ30's Avatar
I am just hoping it's inexpensive- the anticipation is killing me. And bye bye Caribbean money
Old Aug 9, 2012 | 01:46 PM
cjones450's Avatar
gear oil has a very specific smell if i was you i would change the rear main and output shaft seal at the same time.
Old Aug 9, 2012 | 01:48 PM
95VQ30's Avatar
update- the inner bearing was shot and now they are getting into the gears/synchros and I think the 6th gear synchro will be shot.
Edit update- synchros good, both sets of bearings are shot. I'm looking at 2k+ for all the parts/ work (trans, flywheel, clutch, etc) >.<
Old Aug 9, 2012 | 02:07 PM
HotshotVQ35's Avatar
how many miles on the car? starting to sound expensive..
Old Aug 9, 2012 | 02:26 PM
95VQ30's Avatar
107k
Looking over $2k in repairs- now I am having trouble finding an Exedy clutch, not the kit- just the clutch disc. Does anyone know if Nissan clutch disc will bolt up to the rest of the Exedy clutch kit(pressure plate & throw out)?
Old Aug 9, 2012 | 03:02 PM
StevieB's Avatar
As I mentioned in your other thread, I installed an Exedy OEM on my car recently, and the throwout bearing from the kit was the exact same part number and manufacturer as the TO bearing I bought from the dealership. The OEM clutch and PP I removed also appeared to be identical to the Exedy parts.
Old Aug 9, 2012 | 03:08 PM
Stonelove670's Avatar
dammn i know that feeling
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
ef9
Oct 4, 2015 08:43 AM
