Noisy ceramic pads? Or what
Old Aug 10, 2012 | 09:07 AM
ill12will8's Avatar
Changed pads to ceramic and now my brakes are crazy noisy. Is this common?
Old Aug 10, 2012 | 09:12 AM
mitrals's Avatar
You might want to take 120 grit sand paper to the rotor surface to get all the other material off. Right now you have competing compounds on there. Then re-bed the pads. Might also take 500 or so street miles to end the noise.
Old Aug 10, 2012 | 09:18 AM
Rods03Max619's Avatar
What type of pads, and are you running blanks, slotted, or cross drilled and slotted, when my pads heat up, start squeaking on stops, just basic ceramics from Napa, got to switch em out for some better ones...
Old Aug 10, 2012 | 03:38 PM
ill12will8's Avatar
I got blank rotors and basic ceramic pads
Old Aug 10, 2012 | 03:47 PM
T_Behr904's Avatar
This...
Also, ceramic pads tend to be noiser anyways. Some are worse than others, but you might not get them 100% quiet. You still might have some noise from time to time.
Old Aug 10, 2012 | 04:42 PM
95VQ30's Avatar
This...
Old Aug 10, 2012 | 05:43 PM
cjandura's Avatar
Did they get bedded correct?
Old Aug 11, 2012 | 01:41 PM
ill12will8's Avatar
I used the sand paper some of the noise is gone but it's there. I'll give it some time and see
Old Aug 11, 2012 | 01:48 PM
cjandura's Avatar
Did you do this?
Old Aug 11, 2012 | 02:06 PM
ill12will8's Avatar
Did you do this?
To my knowledge yes
Old Aug 11, 2012 | 02:14 PM
cjandura's Avatar
Originally Posted by ill12will8
To my knowledge yes
how?
Old Aug 11, 2012 | 03:37 PM
Donnie's Avatar
Each time I get in my 2000 Maxima after it has sit overnight the brakes make a noise backing and pulling up to get out of the driveway. Once I get out of the driveway I never hear the noise again. It's like once they warm up the noise stops. As far as I know they're ceramic pads. I thought maybe the person who installed them didn't use the special lubricate that comes with pads that goes on the metal pieces.
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
A32goldylocks
Sep 2, 2015 06:39 AM
