Eibachs make the *** too low!!
You really don't want to be cutting coils if you're worried about suspension performance. Eibach didn't make the rear too low, Nissan did. Our maxes are "blessed" with higher arches on the front wheel wells. If you adjust it to look balanced, it will actually throw off the balance of the car.
Re: Eibachs make the *** too low!!
Originally posted by maxse01
Anyone know how to make my car look more even. Now it looks like i have 2 fat asses in the back seat all the time! I have eibach pro spring kit with stock shocks. Thanks
Re: Re: Eibachs make the *** too low!!
Originally posted by ehughes
I'm glad I did not order mine yet. Let me know what you end up doing to remedy the problem. Good Luck. Put my stepmother up front and you should be fine.
Originally posted by irvine78
blah blah blah...cut springs make your car handle weird...blah blah blah..i don't think so...how do i know? cuz i did it..
Dude.. simple physics. The springs were enginered to hold a certain weight. You cut the springs and you change their properties. The same weight has to be held by less spring. There is no way a car with cut springs will handle the same as a car with regular springs. Your car may not explode or fall apart on the very first corner but it will handle differently than the engineers who designed the springs intended it to.
The easiest way to raise your cars a$$ is to use spring spacers. They are rubber inserts that go between the dead coils. They are good for raising the car just a tad. They're cheap too.
Oh and Hoon, how's your first day of school? School
it just lowers little bit more...quite honestly, my car handles much better with cut springs than before-cut...from my track experience..
Originally posted by cobymoby
True to a certain extent but by cutting some dead coils would not hurt one bit. But do Eibach's have dead coils in the front??
Mar 12, 2020 12:06 AM
ballerchris510
Sep 11, 2015 05:29 PM
Violator
Sep 9, 2015 10:14 AM
