dyno run
Old Sep 5, 2012 | 01:58 AM
maurice240sx's Avatar
dyno run
I have the following mods. Cattman y-pipe 3"testpipe megan racing 2.5' exhuast 17 degrees timing cattman pop-charger nwp bop and 5piece spacers. My car dynoed at 220 hp. Are these good gains for what i have done to the car. or should i be seeing a little more?
Old Sep 5, 2012 | 02:31 AM
ranmas2004's Avatar
You can look in the dyno section there are LOTS of dynos you can compare against. Also depends on which dyno you used; some read higher some lower.
Old Sep 5, 2012 | 06:21 AM
MrEous's Avatar
^ Jeff™
How do you fit a 2.5' exhaust under there? I figured 3" was about the most optimal.
To answer your question though, 220 sounds low for a 6spd.
Old Sep 5, 2012 | 12:36 PM
schmellyfart's Avatar
Old Sep 5, 2012 | 01:32 PM
Grand_hustle17's Avatar
Naw, its about right seeing he still have all the stock cats in the header manifold... This is why a y-pipe is so pointless for the 5.5... Its about right for the mods he has
Old Sep 5, 2012 | 01:39 PM
MrEous's Avatar
^ Jeff™
I figured a 15% drivetrain loss would leave it at around 220whp stock.
Old Sep 5, 2012 | 02:28 PM
Finchum's Avatar
get those precats gutted, gut the shelf out of the upper intake manifold, and dial in your mods with and air/fuel controller...240 would be your new number, at the lowest
Old Sep 6, 2012 | 02:25 AM
Thanks for responding guys. And sorry for the typo 2.5" megan racing exhuast.
Old Sep 6, 2012 | 06:30 AM
NmexMAX's Avatar
dot dot dot ...
Type of dyno, AFR, syno graph?
You have any of that information?
Old Sep 6, 2012 | 07:09 AM
datdude20's Avatar
without headers....that sounds about right
just buy aftermarket headers
captchaos
Mar 15, 2016 12:18 PM
junito1
Sep 23, 2015 12:14 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ballerchris510
Sep 10, 2015 09:35 PM
