Installed ES Shifter bushings
Old Sep 11, 2012 | 02:43 PM
MaxinO2's Avatar
Installed the ES shifter bushings for my 02' and boy is it tight, I mean the shifting Well I'm headed out to Ace hardware to get a 10mm lock tight nut since I used the original nut and I think its too tight. Its hard to shift right now, I am using soo much force to move it into any gear, and getting it in reverse is a pain in the ***. So I hope getting the lock tight nut and leaving it a tad loose will help with shifting.
Old Sep 11, 2012 | 02:44 PM
Amerikaner83's Avatar
things will settle after awhile too...everything installed properly?
Old Sep 11, 2012 | 02:49 PM
TallTom's Avatar
I used the original nut + loctite and it has served me well for two years.
Old Sep 11, 2012 | 03:01 PM
MaxinO2's Avatar
Install went slow but good, took me about an hour.. Did you guys leave the nut under the shifter column a little loose or is it tight? Do you think it will help loosened?
Old Sep 11, 2012 | 03:09 PM
TallTom's Avatar
I made it snug but didn't tighten it. I think the linkage will bind if it's too tight.
Old Sep 11, 2012 | 04:26 PM
MaxinO2's Avatar
Yeah the linkage was binding making it hard to shift. I installed the lock tight nut and left a small gap on the left side of the bushing to give it a little room.. It feels alot better than before,
AcuraLegend
Oct 17, 2016 08:47 PM
Starrider
Dec 18, 2015 04:43 AM
I<3 A32's
Sep 10, 2015 11:07 AM
Violator
Sep 9, 2015 10:14 AM
