NO power but the car runs smooth
Old Sep 11, 2012 | 05:40 PM
sciff5's Avatar
Just like the title says the car starts drives and idles like brand new
The problem is has been acting suddenly like it has a 4 banger under the hood.
I didn't even know there was a problem until I drove it for an extended period of time and jumped on it as I was pulling into a lane and the car basically just lost any additional power after 3k rpm. Where the engine would normally just be getting into the power band, this thing crawls through the revs and it doesn't build steam smoothly. It acts like a car pulling timing in a big way or something.
I threw some injector cleaner in there and changed the air filter. I just had exhaust work done replacing the muffler section (car was fine afterwards, this came up a couple weeks later) but I'm wondering if the cats are getting clogged that would suck.
No codes being pulled and like I said the car still idles and drives like nomal if you don't need more than about 100hp out of it
Old Sep 11, 2012 | 05:41 PM
Amerikaner83's Avatar
def. could be clogged cats...they usually manifest themselves being a problem in the higher RPM ranges...
Old Sep 11, 2012 | 10:58 PM
dfj240's Avatar
I also vote for clogged cats. Same thing my car was doing, and I spent WAY too much money replacing stuff that didn't need to be. It ended up being a clogged front pre-cat. If you get a chance, use a vacuum gauge and test the manifold vacuum pressure starting at cold and see what it reads after it's warmed up. If the pressure has increased by more than .5 in/hg then you have a clog.
-Nathan
Old Sep 12, 2012 | 02:54 PM
ATL's Avatar
ATL
x2, i have personally seen a 5.5 gen raise 2 in/hg during warm up. then scanned it and it showed 21% load at idle with a 6 speed in neutral. but it would cruise around town just fine under 2500 rpms and it was showing high 20s for mpg. clogged up cats
Old Sep 12, 2012 | 10:00 PM
sciff5's Avatar
I've got a scanguage I'll have to see if it can read these values
Old Sep 13, 2012 | 07:39 AM
ATL's Avatar
ATL
if not, ill link you to a $30 laptop program that does
Old Sep 16, 2012 | 06:05 PM
lowtown90's Avatar
I could use that like if you still have it
Old Sep 16, 2012 | 06:08 PM
ATL's Avatar
ATL
this is the one i use:
Amazon Amazon
Old Sep 16, 2012 | 07:52 PM
Rods03Max619's Avatar
Yes indeed, power just fell off when I had the 03 couldnt pass a Scion Tc on the freeway.....
Old Sep 18, 2012 | 02:45 PM
sciff5's Avatar
How about dirty fuel filter?
this is actually a scary thought, the engine getting enough fuel to idle and drive but then goes more and more lean as the revs climb.
I am trying to think of anything else I should try before going at the cats. I think I'm just going to hollow out the cats. Do I need an o2 simulator if I do that?
Old Sep 18, 2012 | 02:59 PM
andrewmac's Avatar
Damn it. I just bought the Bluetooth one to use with that Torque android app. Now I want that one instead. Oh well, can't hurt to have multiple scanners I guess.
Old Sep 18, 2012 | 03:24 PM
ATL's Avatar
ATL
although i doubt this is it, it is very simple(and probably free) to check. go to your local parts store and borrow a fuel pressure gauge. check your pressure and report back.
do the non fouler trick for like $6 after you gut the cats
i believe that bluetooth setup has a higher refresh rate than the elmscan so its better for real time readings/datalogging. although i LOVE the scanner program, its not the fastest. Also, with elmscan its hard to scan while driving bc the obd port location. i keep knocking the connection loose with my shin while driving... but maybe that has something to do with being 6'8?
Old Sep 19, 2012 | 06:11 PM
LazYRaCeR's Avatar
do a full tune up, if its not the cats, then check the fuel filter, do an oil change make sure the oil filter is on and there is no leaks, make sure you have oil, make sure there isn't a loose hose somewhere. Just do a full 100k tune up you can just call the dealership and ask whats included in the 100k tune up and i'm sure one of those things is the problem, like oil or water pump, thermostat, draining the radiator just a simple tune up could fix, if not, then you might have lost compression in a cylinder or something or have a spark plug that doesnt fire or something. check 02 MAF and any other sensors, tranny fluid, alternator, any belts, hoses, gaskets, or if theres some water in your intake or exhaust manifolds or some other substances. your tires might be flat, its all I can think of a off top...
Old Sep 19, 2012 | 08:38 PM
sciff5's Avatar
Some scary advice right there
Yikes...
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
