VQ35DE (2002-2003) Ignition Timing Question
Old Sep 17, 2012 | 06:58 PM
Gugs's Avatar
When the base timing is set using the Consult, does the ECU make changes to the setting on its own?
Old Sep 18, 2012 | 07:52 AM
TunerMaxima3000's Avatar
The ECU won't change base timing, base timing is base timing.
Are you talking about the 2* advance? Or just in general?
Old Sep 18, 2012 | 10:16 PM
Gugs's Avatar
I'm referring to the timing that is adjustable +/- 5-degrees using the Consult or equivalent.
Old Sep 19, 2012 | 08:46 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
it is adjustable to 17 degrees with consult. With the utec and haltech you can advance further.
Old Sep 19, 2012 | 08:52 AM
Gugs's Avatar
So my question is... once the timing is adjusted to whatever setting, does the stock ecu adjust the base setting on its own?
Old Sep 19, 2012 | 09:21 AM
Unklejoe's Avatar
The ECU calculates the amount of timing to give based on a bunch of conditions. The base timing is a constant that is applied to the calculated value.
Old Sep 19, 2012 | 02:58 PM
This is what I was trying to say earlier.
Your base is YOUR BASE. It's adjusted from there depending on a whack of stuff, load, temp, rpm, knock levels, and so forth.
Old Sep 19, 2012 | 10:42 PM
Gugs's Avatar
Yes, I totally understand that the ECU is constantly making adjustments to the timing advance/retard as needed.
So when I hook up the Consult (or equivalent) to make an adjustment to the timing (say 17 degrees for example) and drive the car for several thousand miles, will the 17 degree setting still be unchanged in the ECU or will the ECU have made adjustments as needed? In other words, if I were to hook up the Consult several thousand miles down the road, will the 17 degree setting still be there?
Thanks guys.
Old Sep 20, 2012 | 06:02 AM
If it's properly 'flashed' then yes, it will.
I've heard that if you run incorrect gas for the 2* advance though (89 and especially 87) then it can 'revert' back to the stock timing. Not sure about this though
Old Sep 20, 2012 | 10:19 AM
Prophecy99's Avatar
i should check that, I had mine advanced 2* and was running 89 with it for...about 10k miles. since april I switched to 91-93.
I was under the impression it would never change back though.
Old Sep 20, 2012 | 10:19 PM
Gugs's Avatar
So earlier today I had the diagnostic computer hooked up and played around with various timing values. Unfortunately, the adjusted timing values do not retain in the memory of the ECU. Bummer.
tsi6001
Oct 3, 2022 10:23 PM
trasmadean
Jan 20, 2018 05:05 AM
Fakie J Farkerton
Oct 14, 2015 06:25 PM
max_speed97
Aug 26, 2015 07:46 PM
maxima297
Aug 3, 2015 12:50 PM
