help
Old Sep 19, 2012 | 03:56 PM
suecer's Avatar
help
hi guys,
have a huge problem i went unplug a cable which i fought was the amp cable, now the car will not start....all help is need.
Old Sep 19, 2012 | 05:31 PM
gavin68's Avatar
Take a picture of what you're looking at?
Old Sep 19, 2012 | 05:36 PM
2brosgixxer's Avatar
Plug said wire back in and start car??
Old Sep 19, 2012 | 05:41 PM
MrEous's Avatar
^ Jeff™
Sounds like the muffler sensor...
Old Sep 19, 2012 | 05:50 PM
suecer's Avatar
it was the ecu i unplug by mistake.......reading a couple post disconnect the battery for thirty minutes try that but still no lucky...
Old Sep 19, 2012 | 05:53 PM
Not sure how you confuse ECU with an amp wire...able to take a pic though?
Old Sep 19, 2012 | 06:04 PM
suecer's Avatar
sorry guys but its dark ....when i pull it out it had about 30 and more pins... the jack was plug in a metal box silver next to the gas accelerator ...
Old Sep 19, 2012 | 06:34 PM
BigLou55's Avatar
Old Sep 19, 2012 | 07:15 PM
nismopc's Avatar
Those d@mn flux capacitors. Put them in crooked and messes everything up. Check to make sure all connections are in full contact with the flux cap and you should be good to go. Happens to me all the time. Worse I had it, caused my car to go in limp mode and I couldn't get it over 88 MPH. Ruined my travels...
Old Sep 19, 2012 | 07:32 PM
cjandura's Avatar
Man he is gonna need a Haltec and Surratt harness with a 6mt swap and a kaleco O pipe to fix that pickle he got himself into. FFS!
