Tranny Shot?
Old Sep 21, 2012 | 07:32 AM
tseng1023's Avatar
Tranny Shot?
So over time I've had a clunk going from P to D that developed to get worse and worse. Now when I'm driving the acceleration seems wacky and it won't change gears. The RPMs keep going without shifting. When it does shift it gets a jump into the next gear. Do I need a new tranny or can this be something else?
Old Sep 21, 2012 | 07:58 AM
Galactica's Avatar
Aren't there a bunch of shift solenoids that control gear shifts? If one of those are bad I imagine it would do that. Maybe TC going bad? How's the fluid and how many miles on the trans?
Old Sep 21, 2012 | 08:40 AM
tseng1023's Avatar
Gotta check the fluid, what would be wrong with the TC? Trans has 152k, original trans.
Old Sep 21, 2012 | 08:55 AM
BigLou55's Avatar
IIRC the solenoids would store a code in the TCU if they are bad(0/D or A/T light would blink 16 times upon start up). Do as galactica said and check that your fluid is at the correct level and doesn't smell burnt.
Old Sep 21, 2012 | 10:31 AM
watut's Avatar
Any codes? My friend had a similar problem in is 98 i30. We changed the resistor beside the airbox on the front drivers side strut tower and that fixed the problem.
Old Sep 21, 2012 | 08:27 PM
maxed_out_99's Avatar
check the mount.
have a friend sit in your car with it idling and go from p to d continuously while you watch it if the trans moves alot replace the mount
Old Sep 23, 2012 | 06:51 AM
tseng1023's Avatar
Ok so I drove it yesterday and I noticed that when accelerating the RPM's keep on building as said before and I have to let off a little and get back on the gas for it to upshift...Weird..
Old Sep 23, 2012 | 11:41 AM
BigLou55's Avatar
^^^did you check your fluid though?
Old Sep 28, 2012 | 11:06 PM
tal27416's Avatar
Same issues (possible fix
I have had the same issues and had the tranny rebuilt laste year but now the issues are back so i found another thread that was helpful and im looking into buying a kit that many ppl have claimed to work
http://transgoonline.com/products.ph...dcountview=Yes
here is the link to the kit that has claimed to work. I am ordering mine tomorrow and will let you know know how it worked
link to the thread i found the info in
http://forums.maxima.org/6th-generat...blem-help.html
Old Sep 29, 2012 | 07:37 AM
cjandura's Avatar
The transgo kit does not fix the trans it only stiffens up the shifts if you clutches are burnt it makes it worse i have the kit.and if you do rebuild the trans pick up the solonoid tsb kit for $80 the regular price for it is $400
Sent from my ****
Apr 16, 2020 05:15 AM
HOKUSMAX
Nov 13, 2017 04:34 AM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
pktaske
Sep 4, 2015 08:40 AM
