2001 20th anniversary headlights
Old Oct 1, 2012 | 10:50 PM
Freshprince's Avatar
This is my first time goin on a forum but I need help. I wired a hid kit into my car and either the high or low beam is working (bi-xenon). I don't know which one and it won't switch between highs and lows. I took out the wires leading to the harness and tried hooking them up in all orders and dint work...
Please help as soon as possible with a solution.
Old Oct 2, 2012 | 07:31 AM
Galactica's Avatar
That's a hard problem to help with without pictures and more information. Generally these kits are made to plug into factory harnesses, so they are essentially plug and play unless you get a 55W kit and buy the extra wire harness to handle the extra load in which case you have a switching coil. In other words, the members here need more info and also pictures to be helpful.
Old Oct 2, 2012 | 01:24 PM
watut's Avatar
I had a similar problem. tried different wiring configurations but nothing seemed to work. Could only get low beams to work, if I tried switching to high beams it would all just flicker. I just gave up on it.
Old Oct 2, 2012 | 03:17 PM
TunerMaxima3000's Avatar
Way more info needed.
Old Oct 2, 2012 | 04:33 PM
Totalpckge1's Avatar
Check to see if the ballast is defective. It happened to me a couple of times. Take the ballast from the side that is working and try it on the side that's not working and see if it works. If it does work then there is your problem.
Old Oct 2, 2012 | 07:26 PM
gapboi210's Avatar
The maximas just use one bulb for high and low beams right?
Old Oct 2, 2012 | 07:30 PM
Galactica's Avatar
2000 and 2001 Maximas only use one bulb. 02-03 have factory HID lows and halogen brights (I'm pretty positive anyway...)
Old Oct 2, 2012 | 09:47 PM
Sheepdog1775's Avatar
Yep.
Old Oct 2, 2012 | 10:36 PM
user 11122324
42
Jul 18, 2022 03:35 PM
AaronL
Aug 8, 2020 10:31 AM
doctorpullit
Oct 28, 2019 10:58 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
