Tranny Problem
Old Oct 10, 2012 | 08:29 PM
98maxi's Avatar
Tranny Problem
The car is an 02 max. The car shifts gears without any problems. Once you get to a stop light and take off, the car will not shift out of first gear. If you pull over, put the car in park, shut it off and restart the car, it shifts and drives fine. It's annoying to have to shut the car off at every light to turn the car back on to get it to drive normally. Has anyone had this problem? What could be the cause of it?
Old Oct 10, 2012 | 08:41 PM
erictown's Avatar
not quite get your problem, how do you tell when you stop at a light that AT doesn't shift out first gear? engine stalled ?
Old Oct 10, 2012 | 08:50 PM
98maxi's Avatar
After I come to a complete stop and try to take off, the transmission does not shift out of first gear. If I pull over to put the car in park to turn shut it off. Once I turn the car back on and put it drive, the transmission shifts fine.
Old Oct 10, 2012 | 09:20 PM
erictown's Avatar
got it.
1, check ATF, many tranny problem only come out from low or dirty fluid.
2, reset computer, battery disconnected for 30 min. and reconnect, wait 10 min before you first start car. let computer to reset.
3, if problem remains, check error code.
Old Oct 10, 2012 | 09:46 PM
maxed_out_99's Avatar
sounds like a TCM/solenoid/speed sensor
fluid level and code check is where i would go first
Old Oct 11, 2012 | 07:50 AM
watut's Avatar
Had that exact same problem in a Accord, it was the tranny
Old Oct 11, 2012 | 04:39 PM
tophersmadmax's Avatar
Had same problem. Replaced revolution sensor in mine as friend at Nissan (service mgr) told me to do and it fixed the problem. Not sure if this is the same problem, but sounds similar. hit gas and goes no where maybe 20 mph with high rpm. Pull over and restart and drives normal. Would happen sometime when I was slowing down or under hard acceleration too. Find link to pics below
http://api.viglink.com/api/click?for...13499971485683
Old Oct 11, 2012 | 07:19 PM
98maxi's Avatar
I found the problem and fixed it after replacing a few parts.
1. The VIAS mechanism was broken as it started to rattle like a rattle snake. I had a BOP around so I used it to fix that problem for good.
2. The proper amount of ATF was added and checked to make sure the amount was sufficient.
3. The two revolution/speed sensors were replaced with OEM units from a local dealership. But, the problem was still there. So, I decided to swap the two sensor connectors, although I was certain that I did not mix the two connectors. It worked, the car drove fine afterwards. The transmission shifts extremely smooth now. The thourough flush was much needed.
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
