Secondary Intake throttle Plate CAUTION
Old Oct 16, 2012 | 08:52 PM
96SEMaxima's Avatar
Hey everyone just a heads up to 02 and up 3.5L owners. I just went through one of the biggest headaches any nissan owner should avoid. My wife's 02 Max started to knock one morning sounding like a bad rod bearing. After taking the car apart some what and doing some research online, I found that the 3.5 has a secondary intake throttle plate inside the intake manifold. Located on the passenger side of the engine it has a vacuum operated plunger that opens when you are on the gas pretty hard. After taking the secondary intake throttle out of the intake I noticed that one of the small screws holding the plate to the shaft was gone. You guessed it inside the engine. Not sure what nissan was thinking but they should have used thread lock or peaned the screw so it would not back out. Lucky for me the screw passed through the intake and went out the exhaust, but not before it made some ugly marks inside the combustion chamber.
Old Oct 16, 2012 | 09:13 PM
Child_uv_KoRn's Avatar
Bad *** Newb
It's a known, but rare problem on maximas. Sentras really had this problem on the TB butterfly.
Why did you not have a BOP installed anyway
Old Oct 16, 2012 | 10:16 PM
ShocknAwe's Avatar
Bop
Old Oct 17, 2012 | 12:54 PM
TunerMaxima3000's Avatar
that 'secondary' throttle is actually your "VIAS" or "variable intake".
Old Oct 17, 2012 | 06:26 PM
ranmas2004's Avatar
Get rid of that VIAS garbage and get a BOP.
Old Oct 17, 2012 | 08:43 PM
You guys and your BOP's. Placebo effect in full effect.
Old Oct 18, 2012 | 12:26 PM
defiance's Avatar
Can one of you guys Elaborate what a BOP is ?
First time in ever hearing of this ..
Old Oct 18, 2012 | 02:07 PM
Block off plate. VIAS delete. Same thing.
Doesn't apply to the 00/01
Old Oct 18, 2012 | 07:43 PM
spock's Avatar
No placebo when you lose your bottom end grunt. Still not sure about the top end gain. Phenolic spacers are a big plus in regaining mid range though.
Old Oct 19, 2012 | 12:27 AM
RR5's Avatar
RR5
This happened to me years ago and the Nissan stealership wanted $1,600 to replace the throttle body. Had to fight it out with the extended warranty but I ended up winning. Stoopid stealership tech told me "I revved the engine, noise gone. Here's what I think is the screw"..
knight_yyz
Nov 1, 2015 01:34 PM
MichMaxFan
Sep 30, 2015 09:18 AM
ricky7780
Sep 24, 2015 06:50 PM
