VIDEO FIXED! ABS Pulsing in Reverse? Help Please!
Old Oct 20, 2012 | 07:26 PM
Chuckles03SE's Avatar
Firt of all, I'm sorry to the 20 orgers that wasted a click on this before I got the video fixed. I didn't realize I didn't know how til I tried to do it. I still didn't get it playable from the thread, it'll take you to photobucket. Here's the deal:
I've had my '03 SE Auto for 6 years now and I love my baby except for this issue. When you're backing up at like 10mph and hit the brakes it makes a strange clicking/clunking sound that is definitely coming from the front end and acts like it's not going to stop. I know, I know, there's no reason to go backwards that fast but it still concerns me. The brake pedal pulses in unison with the clicks. I'm pretty sure it's ABS related but I have no idea why it does it. I've asked some mechanic buddies of mine and they agree it's probably ABS but they're clueless beyond that so I finally took a video and figured I'd turn ya'll loose on it. Everything functions perfectly when going forward and my ABS light is not on. Any suggestions are greatly appreciated. Again, I apologize for the first thread. I hope I don't get demoted back to noob status! Hahaha!
Old Oct 20, 2012 | 09:16 PM
Anybody? It's kinda tough to hear but it's there. 36 views and no replies. This isn't looking good.
Old Oct 21, 2012 | 05:42 AM
nismonegro26's Avatar
Sound like one of the ABS sensors are bad. I had the same problem on my daughter's. Hers would act up between 10 mph and coming to a complete stop. When I took it off I noticed it had grooves cut into the magnate
Old Oct 21, 2012 | 10:14 AM
Ya think? It's just odd that it only does it in reverse. Is there a way to test the sensors to determine which is the problem?
Old Oct 21, 2012 | 12:41 PM
No way to test them, I found out which one was bad because that rotor was turning blue because the ABS was kicking in on that one side
Old Oct 22, 2012 | 08:10 PM
djfrestyl's Avatar
Suspension Yoda
That's a new one. I'm not 100% but here's a way to narrow it down:
If you suspect the ABS sensor you could always remove it (carefully) and see if the noise goes away. Your light will be on but that's ok. If the noise is gone replace the (already removed) sensor with a new one. If the noise is still there...reinstall that sensor
Old Oct 23, 2012 | 05:42 PM
Just looked at you video and thats the same noise I was getting.
Old Oct 23, 2012 | 06:34 PM
BigLou55's Avatar
I'd do what DJ is suggesting, however just so you know, the abs sensor CAN be tested using a multimeter. Its in the FSM(search the org for a link to the FSM).
Old Oct 24, 2012 | 06:36 AM
Didn't have a chance to pull sensors yesterday but I got to thinking. I feel like a jacka$$. I actually paid attention this morning and my ABS light does not light up when starting the car. All my other lights, SES, Tranny etc. light up for a second then go out as they should. Shouldn't the ABS be coming on and running onboard diagnostics and then either going out if all is well or staying on if there's issues?
Old Oct 24, 2012 | 07:19 AM
BigLou55's Avatar
^^^If it doesn't come on at all, even at startup, your bulb is probably just burned out. Its pretty simple to replace that bulb after removing about 4 screws IIRC to get the cluster out.
Old Oct 24, 2012 | 07:50 AM
Thanks fellas. I'm not really worried about pulling the cluster as I've done all my own stereo installs since I started driving, interiors are kinda like lego's. I've been thinking about swapping over to LED's anyway so I may just wait til I come to a final decision on that. Also the clear plastic gauge cluster cover has a burn mark on it that gets on my OCD nerves when I detail my car so I may replace it all together. If I choose not to go LED I'm assuming I can pick up the ABS bulb at the Stealership for around $5 or are they standard Parts Store stuff?
Old Oct 24, 2012 | 08:42 AM
It actually does come on at Start Up, when I looked this morning I had only had car off for less than a minute while running into the store. I just picked it up from the Inspection Station and it DOES in fact come on then go off almost immediately as it should. I just feel like if a sensor was bad it would catch it and stay on. I guess I'm back to pulling the sensors individually and seeing if the problem persists with them out/disconnected.
Old Oct 24, 2012 | 09:09 AM
Well the light in my daughters car never came on. It just came on just when starting up but it cut right off
James92SE
142
Jan 2, 2024 09:23 AM
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
