02 Maxima - Possible engine leak?
Old Nov 6, 2012 | 07:15 AM
maximalxl's Avatar
I just did oil change on my 02 max (104k miles on it).....about 4300 miles ago i put in 5qts of Mobil 1 fully synthc.....and took out 2.5qts....any help to fix the issue is appreciated....hopefully there is a how-to out there...
thanks
Old Nov 6, 2012 | 07:33 AM
andrewmac's Avatar
Sounds like you have an oil burner.
Old Nov 6, 2012 | 07:38 AM
nishfish871's Avatar
You have a few options to prevent it from getting worse and maybe reduce it.
1. Install a new 6th gen rear (right) valve cover and gasket.
2. Gut the precats (in the header/collector) or get aftermarket headers.
3. Check the front valve cover. If caking of oil, replace the gasket.
4. Sell it
Old Nov 6, 2012 | 09:21 AM
02whitemaximase's Avatar
I have done all of the above listed things except I have headers. No change and still burn a couple quarters every 2,500 miles. I use full synthetic too, the best thing to do is to change to a thicker non synthetic oil. I've read that that significantly helps.
Old Nov 6, 2012 | 04:47 PM
Try 5w 30
Old Nov 6, 2012 | 06:12 PM
maximalxl's Avatar
Nish I've been using 5w30 .. thanks for everyones input I'll let u know wat works
Old Nov 6, 2012 | 06:35 PM
Looks like you've got to deal with it like the most of us :/
Old Nov 6, 2012 | 07:54 PM
DjHackStyle's Avatar
whats the best oil for an oil burner? i wanna slow down my consumption
MAXSE5SPD
Aug 23, 2015 12:06 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
