Clutch bleed by pressurizing master reservoir
Old Nov 15, 2012 | 08:58 AM
tennis5luv's Avatar
I'm having a very difficult time bleeding the clutch on my '01 Maxima. I've done the pump (both upper and lower with assistant). I've use a Mityvac on both upper and lower but had difficulty getting a good seal as air was leaking from between the threads. My next step is to teflon tape the bleed valves and try the vacuum again.
If the vacuum does not work. Has anyone bleed their clutch by applying light pressure through the master reservoir? Please tell me your success story.
Old Nov 15, 2012 | 08:11 PM
fishtale6spd's Avatar
Well we have a 2000$ pressurized machine just for bleeding fluid lines like brakes clutch whatever I'm a mechanic. Only uses 10lbs of pressure though so be carefull not to blow the seals out of the reservoir with however your going to do this but Goodluck man it works amazing for our stuff
Old Nov 16, 2012 | 07:17 AM
CMax03's Avatar
Yes it works either way! Some like it sucked, Some like it Blown! I personally like mine sucked!
user 11122324
42
Jul 18, 2022 03:35 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
