traction control light and TC off light stay on
Old Nov 19, 2012 | 12:10 PM
kurbin's Avatar
I've had the cv shaft out, because a shop had installed the wrong cv shaft, i changed transmission oil, bleed the brake fluid with Dot 3 and all of a sudden I'm driving and the lights come on...the brakes start seizing only in the front.
I've replaced one caliper, both front pads and rotors. This hasn't changed anything, I think its the master cylinder, but I'm not sure why the TC light and TC off light are on...I think these have something to do with the brake problem, only I haven't been able to find out what else these lights would mean, other then the obvious.
Old Nov 19, 2012 | 08:06 PM
kurbin's Avatar
okay so i have to revise this slightly...I have the slip/tsc off/engine light come on, the seizing brakes were fixed. my problem is that when i reset the codes and drive it around none of the lights come on, the moment i shut it off for five minutes then the lights come back on...I'm seriously stumped
Old Nov 21, 2012 | 03:03 PM
nsnrider's Avatar
ok, there are currently three threads on the first page about the same issue, does anyone even attempt to search before starting a new thread?
OP, change your abs sensor.
Old Nov 21, 2012 | 10:30 PM
kurbin's Avatar
the check engine is related to the misfire on cylinder no 3 which is now fixed.
The slip/off TCS are the lights on the dash now but no ABS, yes I already read the other threads, randomly replacing sensors seams sort of expensive.
Old Nov 21, 2012 | 11:19 PM
kurbin's Avatar
thanks for the suggestion nsnrider, but I'm not sure the abs sensor is the issue. If you know a way to trouble shoot I'm all ears
King_Ten_Ahead
Sep 30, 2015 04:27 PM
Jeffesernia11
Aug 23, 2015 06:09 PM
maxocar
Aug 21, 2015 12:57 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
