2000 maxima se no power locks
Old Nov 26, 2012 | 08:17 PM
heavyarty's Avatar
as stated in the title. the power locks and remote entry unlock/lock doesnt work anymore. seemed like it went bad over night. everything is fine just have to use key to open the car. what can be the cause behind this?
Old Nov 26, 2012 | 08:55 PM
rebelhell's Avatar
I'd start with fuses and work from there. you have fuse boxes under the dash AND in the engine compartment. Check both.
Old Nov 26, 2012 | 09:14 PM
heavyarty's Avatar
which of the fuses should i be looking that could possibly be bad?
Old Nov 26, 2012 | 09:27 PM
rebelhell's Avatar
If you open the covers there should be a diagram that will show what each fuse is for. Also check the FSM. Here's a link if you don't have one. http://www.nicoclub.com/FSM/
Old Nov 26, 2012 | 10:30 PM
joshmachine's Avatar
If you are looking to reprogram your remote, these are the steps
1.Get in & lock the doors
2.Insert the key into the ignition 6 times within 15 seconds
3.Hazard lights should flash
4.Put key back into the ignition & turn to Accessory
5.Press the master door lock (on drivers door arm rest) unlock/lock
6.Hit the lock button on the remote
7.Hazards should flash
8.Pull key out and open the drivers door and then close it
9.It should be set
Old Nov 26, 2012 | 11:12 PM
rebelhell's Avatar
9.It should be set
He said his power locks don't work at all. That's not a programming issue.
Old Nov 27, 2012 | 11:49 AM
heavyarty's Avatar
and today i noticed that he rear defroster isnt working. is this signs of things to come or just sheer coincidence
Old Nov 27, 2012 | 12:58 PM
heavyarty's Avatar
all the fuses worked fine. i reset the secu and everything is back to normal! thanks everyone
Old Dec 11, 2013 | 02:08 PM
mfshin's Avatar
I have same problem without power for door locks / rear defrog / indoor lights.
Can you describe how you reset the SECU box?
LilVito
Oct 25, 2019 08:12 AM
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
kjm900r
Aug 5, 2015 07:14 AM
