Pre-cat gutted question
Old Nov 29, 2012 | 12:36 PM
gsxr-rider137's Avatar
ok..a few weeks ago my car started to run real bad...and then it completely dies...would turn over ,but no start. took it to a mechanic friend of mine , and he found out the fuel pump went bad. but it didn't just stop working. apparently...it was slowly losing fuel pressure. (explains why the car was running bad) and made the car go real lean..which in turn melted the front pre cat and the main cat as well. i wasn't about to install new pre cats (their huge $$)so i had him gut the pre cat and main cat. this should be done tomorrow and i hope the car is back to normal....but what issues am i going to run into with the pre cat nd main cat gone...besides emmisions...AND ..if i just put a main cat back in it...will it pass emmisions..?
Old Nov 29, 2012 | 12:38 PM
[s3]'s Avatar
Pass emissions? yes
Old Nov 29, 2012 | 12:41 PM
then what is the pre cat function? should i have him gut the rear one as well?
Old Nov 29, 2012 | 12:44 PM
[s3]'s Avatar
Pre cats helps with emissions when the car starts up, when your car is warmed up you only need the main cat to pass emissions.
If you don't give 2 ***** about emission, gut them both.
Old Nov 29, 2012 | 12:50 PM
nishfish871's Avatar
I say gut the precats, do the nonfouler trick, and replace the main cat with a testpipe. Depending on inspections are, put the main cat back on for it.
Ebay a 240sx test pipe.
Old Nov 29, 2012 | 04:15 PM
whats the " nonfouler trick" ??
Old Nov 29, 2012 | 04:44 PM
Galactica's Avatar
A spark plug antifouler will basically screw in to the port for the O2 sensor and then you screw the O2 sensor back into the antifouler with the effect being that you draw the sensor out of the exhaust stream and thus cause that difference in readings from main to rear sensors that would normally be there with a cat.
Old Nov 29, 2012 | 06:14 PM
TallTom's Avatar
Does your state do the ODB2 scanner test or the meter in the tailpipe test? If ODB2, you will need o2 simulators or non-foulers to trick the system into thinking you have working precats.
Old Nov 29, 2012 | 07:43 PM
Maxx6spd's Avatar
how much did they charge you to gut the pre cats?
Old Nov 30, 2012 | 02:44 AM
i haven't gotten the bill yet...car should be done today. but i am gonna bet its gonna be some $$. he had to cutt off & fix almost 90% of the bolts that hold all the pre-cats to the Y-pipe.
this wasn't a planned project..
and Ct does have emissions...but i'm not sure if we have that ODB2 scanner test , just a meter in the tailpipe, i think
Old Nov 30, 2012 | 12:47 PM
5aprilc's Avatar
Will antifoulers be needed in every O2 sensor hole? Because I have a Cali spec Maxima, and I was planning on doing the Warpspeed Y Pipe install, also we have the OBDII scanner test in NH, would I pass with antifoulers?
Sorry for the thread jack.
Old Nov 30, 2012 | 01:58 PM
TallTom's Avatar
They are only needed in the o2 bungs that are after the location of where the pre-cats should be. Without them, or o2 simulators, you will most likely get a Service Engine Light and a code which will make you fail inspection.
Old Nov 30, 2012 | 02:00 PM
TallTom's Avatar
You too will need non-foulers or o2 simulators.
Conn testing:
What Should I Do When the “Check Engine” Or “Service Engine Soon” Or Malfunction Indicator Lamp (MIL) Is On?
If your vehicle’s Malfunction Indicator Lamp (MIL) stays on while the engine is running, it’s an indication that the On Board Diagnostic system has detected an emissions problem that has the potential to make your vehicle emit excess emission levels. If your vehicle’s Malfunction Indicator Lamp (MIL) is blinking or flashing, this is an indication that the vehicle has a serious problem and needs immediate service or major damage could occur to expensive emission related components.
Your vehicle will FAIL its emissions test if the Malfunction Indicator Lamp (MIL) is lit when tested. To avoid this, it is suggested that you have your vehicle’s OBDII system diagnosed by a qualified mechanic prior to having it emission inspected.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
