redline in between 5-5500 rpm?
Old Dec 6, 2012 | 07:02 AM
dnice02's Avatar
Lately I've been noticing that sometimes when im driving, and give the car about 80-90% throttle it acts like the rev limiter kicks in. It doesn't do it all the time just some times. Any possible causes? Could i be running out of fuel? I know i need a tune but haven't been able to get one yet. Thanks in advanced.
Old Dec 6, 2012 | 07:05 AM
NmexMAX's Avatar
dot dot dot ...
Sounds like an intermittent MAF issue. Codes?
Old Dec 6, 2012 | 10:02 AM
dnice02's Avatar
I haven't checked, but the check engine light isn't on.
Also it seems to do it mostly after the car has warmed up and its cold outside.
Old Dec 6, 2012 | 11:18 AM
T_Behr904's Avatar
Every MAF i've had go out never tripped the light.
Old Dec 6, 2012 | 11:22 AM
TunerMaxima3000's Avatar
I've never heard of a MAFS tripping a light unless it's a complete short/dead
Old Dec 6, 2012 | 01:53 PM
dnice02's Avatar
I just recently replaced it about 12-15,000 miles ago. They die that fast?
Old Dec 6, 2012 | 02:20 PM
T_Behr904's Avatar
Any part can fail at any time.
Most MAF's fail sooner than they should due to air filter oil (K&N for example) . Others just because it's a cheaply manufactured part in China, because many aftermarket parts don't have the best quality control, so it's a roll of the dice on how long it will actually last under normal operating conditions.
Old Dec 6, 2012 | 03:25 PM
cjandura's Avatar
Nmex you been hiding brudder!
Sent from AznRyan's Cat Farm
Old Dec 6, 2012 | 04:17 PM
dnice02's Avatar
It's a genuine nissan part, i bought it from the dealer and i have an AEM dry flow filter. So idk
Old Dec 6, 2012 | 05:53 PM
gapboi210's Avatar
When you say like it hits a rev limiter does it stop increasing in the RPMs but hold a steady RPM, does it just fall back to an idle....?
Old Dec 6, 2012 | 07:38 PM
dnice02's Avatar
It bounces just like you hit the rev limiter, until i shift to the next gear. I just got back from driving it earlier, and i was playing around and it didn't do it so????????
Old Dec 6, 2012 | 08:08 PM
gapboi210's Avatar
I wonder if your tach is inaccurate and you are hitting a rev limiter
Old Dec 6, 2012 | 09:23 PM
rebelhell's Avatar
That would be easy enough to check if you have something like Torque Pro or Dash Command. Just pull the RPM's from your ECU.
Old Dec 6, 2012 | 10:07 PM
Good thinking boys!
user 11122324
42
Jul 18, 2022 03:35 PM
Unclejunebug
Apr 2, 2016 05:42 AM
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
