P0128
Old Dec 15, 2012 | 11:37 PM
uptownsamcv's Avatar
P0128
i was wondering what kind of problems can relate to a code P0128?
my car has a bad sputter wich i posted up in another thread, http://forums.maxima.org/5th-generat...7-shaking.html.
tonight as i got close to home i noticed that my temperature gauge was a bit lower than usual and i didnt feel any sputter or hesitation for the past mile or 2.. so i went ahead and stopped the car than floored it through 1st 2nd and 3rd and didnt get any sputtering or hesitation. this was all after a 1 hour drive from work.
could there be some kind of connection between my engine sputtering and the code P0128?
Old Dec 16, 2012 | 05:30 AM
rebelhell's Avatar
I doubt it's causing your shaking but you should check your coolant levels and replace your thermostat with a new OEM. If this doesn't solve your P0128 then you could possibly have a bad engine coolant temp sensor.
Old Dec 16, 2012 | 06:48 AM
just seems odd that after about a hour of driving the sputter goes away. ive been thinking it has to do with the engine temperature cause it only does it when the motor is fully warmed up. than last night after an hour drive from work the temperature gauge seems a bit lower than usual and the sputter goes away completely.
Old Dec 16, 2012 | 01:11 PM
gapboi210's Avatar
I had a Camry once that was running like crap when it was cold. I had a similar code, replaced the coolant temp sensor and it cleared up.
Old Dec 16, 2012 | 09:29 PM
I know it affects the air fuel ratio. when my crx had air in the cooling system it would run real bad. it would flood the motor at idle and take a while to crank up.
Old Dec 16, 2012 | 10:18 PM
gapboi210's Avatar
actually i think my Camry was the other way around...ran better cold when it had the faulty temp sensor
Old Dec 17, 2012 | 04:37 AM
same way with this maxima, doesnt act up till its fully warmed up.
dbavaria
Jul 26, 2016 04:13 AM
markeldeiry
18
Jun 7, 2014 11:45 PM
mrodenberg0124
19
Jun 26, 2012 01:23 PM
DOHCtorJT
Nov 11, 2008 09:44 AM
