Here's the full TSB list
Old Nov 16, 2010 | 07:41 AM
mrodenberg0124's Avatar
Hey guys,
I was at my roommate's body shop and got bored and printed out the TSB list for our cars from AllData. I didn't feel like clicking on each one and printing out the full TSB details, but this will at least give you the general idea. If there's enough interest i may go back and get everything. Enjoy.
10-043 03/17/2010 A/C - Compressor Clutch Replacement Information
10-044 03/17/2010 A/C - TXV (Thermal Expansion Valve) Replacement
10-026 02/18/2010 A/C - Interior - Climate Control Seat Issues
10-028 02/24/2010 A/T - MIL ON/DTC's P0740/P1777 Set
10-003A 02/11/2010 A/T - 5 Speed A/T DTC Diagnostics
09-140 12/08/2009 A/T - CVT Oil Leak Diagnosis Information
09-138 12/18/2009 A/T Controls - Booming Noise Between 20 & 45 MPH
09-135 11/23/2009 Antitheft System - Electronic Steering Column Lock Info
10-069 05/19/2010 Body - Rear Wheel Mud Guard Loose/Comes Off
10-063 05/03/2010 Body - Sunroof Glass Panel Chatters When Operated
10-077 06/10/2010 Brakes - ABS Self Check Noise Explanation
^Clicking, knocking, clunking, buzzing, or thumping noise coming from the engine compartment area; and
^The noise occurs only once during the first few seconds of driving at approximately 16 MPH; and
^The noise occurs only once per ignition cycle (ignition OFF > ON) and does not occur again until the ignition is cycled.
NOTE:
The noise may be louder after the vehicle has not been operated for a prolonged period of time. The above condition is normal and does not need repair. Each time the ignition is turned on and the vehicle is driven at about 16 mph, the ABS/VDC system performs a "Self-Check" to confirm components of the ABS/VDC system are operating correctly. This "Self-Check" function created the noise described above. If the brakes are being applied when the "Self-Check" occurs, a vibration may be felt in the brake pedal and an increased level of noise may be noticed.
NOTE:
^Refer customers to the Owners Manual, Section 5, Starting and driving, Brake system on the Anti-Lock Braking System (ABS). The "Self-test feature" section provides additional explanation.
^The speeds described above refer specifically to Versa, Sentra, Altima, and Maxima. However, any vehicle fitted with ABS or ABS/VDC will have a "Self-Check" which is triggered in similar circumstances.
10-068 07/09/2010 Campaign P0337 - Navigation Software Updates
10-066 05/07/2010 Computers/Control - CAN Code, Diagnostic Tips/Guidelines
09-040A 05/14/2010 Cooling System - Long Life Coolant Information
10-079 06/21/2010 Electrical - MIL ON/DTC P0128 Due To Remote Start Sys.
04-049G 04/27/2010 Electrical - Trailer Lighting Wiring Information
09-020A 03/05/2010 Emissions - EVAP System Leak DTC Diagnosis
09-129 11/17/2009 Emissions - EVAP Canister Vent Control Valve Replacement
10-002 01/12/2010 Engine - Drive Belt Noise Diagnosis
09-141 12/08/2009 Engine - Reman Engine Start Up Lubrication Information
10-085 07/16/2010 Engine Controls - DTC's P0133/P0153 Stored in ECM
10-078 06/21/2010 Engine Controls - ECM Programming Interruption Recovery
10-009 01/19/2010 Engine Controls - Seized O2 Sensor Removal Procedure
09-136 12/01/2009 Engine Controls - ECM VIN Registration Procedure
00-052 05/16/2009 Engine Controls - ECM Replacement Procedures
10-017 02/01/2010 Instruments - Fuel Gauge Issues/DTC'S P0461/P0462/P0463
09-092B 06/16/2010 Interior - Driver's Seat Botton Shifts/Rocks Slightly
09-085A 05/28/2010 Interior - Cup Holder Lid Won't Open Or Close
09-077 03/15/2010 Interior - Seat Back Board Removal Procedure
08-008C 09/15/2009 Keyless/Antitheft Systems - NATS/Intelligent Key Info
09-118 10/28/2009 Keyless Systems - Intelligent key(R) Battery Replacement
03-074E 01/04/2010 Lighting - Exterior Lamp Fogging Inspection
03-015B 12/21/2009 M/T - Warranty Repair Fluid Requirements
10-033 03/01/2010 Navigation Radio - AV Control Unit Configuration
09-105A 04/07/2010 Navigation System - Software Update For Various Concerns
10-023 02/16/2010 Navigation System - Map Does Not Match Vehicle Position
09-086 10/06/2009 Recall PC012 - Front Strut Insulator Cracking
10-053 04/13/2010 Starting System - Can't Turn Ignition To ON Position
10-020 02/12/2010 Suspension - Creak/Groan From Front Strut Area
10-048 03/22/2010 Tire Monitoring System - Diagnostic Tool
08-033A 10/16/2009 Tires - Tire Pressure Information
09-131 11/18/2009 Vehicle - VIN Plate/Certification Label Replacement
10-061A 06/29/2010 Xenon Headlamp Service Info.
Old Nov 16, 2010 | 11:04 AM
Dubl-A's Avatar
Nice, thanks for posting!
Old Nov 16, 2010 | 04:45 PM
Compusmurf's Avatar
Love my '09
Added into the FAQ section!!!!
Old Nov 21, 2010 | 11:37 PM
OneWhtMax's Avatar
thanks
Old Nov 25, 2010 | 06:03 AM
MaxUp's Avatar
thanks for sharing. I found this information very useful.
Old Nov 26, 2010 | 07:12 PM
denny_1986's Avatar
NOTE:
thanks for this!
i bought an 2011 sentra a week ago and it too keeps doing the same exact thing as mentioned in the maxima tsb. Glad its just a safety feature
Old Nov 27, 2010 | 02:55 PM
smarty666's Avatar
TSB List
Not that I'm complaining, because the list you gave is great and nice to have on here but your missing one for the front passenger seat vibration/shaking at highway speeds. Only reason I know this is I printed it out from nissanhelp under the 2009 Maxima even though I have a 2010 but it is doing the same thing as the 2009 are.
Old Nov 29, 2010 | 10:08 AM
Is this one not the same TSB?
I can only list what was in the AllData TSB list If you have any additional ones feel free to list them and i'll add them to the original post.
Old Dec 3, 2010 | 02:12 PM
WifPd4's Avatar
Where are the TSB available ? Is the database by VIN number ?
Old Dec 3, 2010 | 02:18 PM
smarty666's Avatar
Here it is
No it is a different one. It is this one:
09-041a 06/08/09 Front Passenger Seat Shakes at Highway Speeds
http://x.nissanhelp.com/forums/Knowl...d&pp=12&page=5
Old Jun 8, 2011 | 09:24 AM
Dave Marques's Avatar
Thanks for the Listing - Very Helpfull - If you do get the chance - the details would be much appreciated!!
Old Aug 14, 2011 | 01:55 PM
zman764's Avatar
I have had continued and ongoing issues with my climate controlled seat in my 2010 max.
Would you be able to post the full text from "10-026 02/18/2010 A/C - Interior - Climate Control Seat Issues" I would like to know what they are now telling the service departments to do to these seats. It took more than a year from the purchase date of my car to have the heated function on my seat to work at all. (bought it in the summer and only used the a/c while test driving)
Old Aug 14, 2011 | 02:51 PM
Dluv's Avatar
this is great, thnx
Old Feb 9, 2012 | 05:04 AM
Eagle6705's Avatar
OMFG LOL that explains the knock after the car starts up after my 16 hour shifts
Old Jun 26, 2012 | 06:49 AM
WrightOne86's Avatar
Bump for those that may have some issues they have been wondering about...
Old Jun 26, 2012 | 07:59 AM
eesjunin's Avatar
Do you have more details on the two below? Thanks!
Old Jun 26, 2012 | 08:22 AM
PSU09MAXIMA's Avatar
the issues with them are that out of nowhere it can fail and wont come out of this so you cant start the car.
Old Jun 26, 2012 | 08:57 AM
AlDente67's Avatar
I have developed a passenger seat rattle lately - this on a 2012 after 4 months of driving (2000 miles). I will bring it up during my first service.
Also, the power under 40mph does seem lethargic to me. I wonder what that TSB entails?
Old Jun 26, 2012 | 09:40 AM
eesjunin's Avatar
Thats what i am trying to pin point. I had then Steering lock module fail last year, i had a huge fight with Nissan corporate about it...so if any of these point to it being a TSB then i might contact them back to further refund me for the Part they replaced on my account.
Old Jun 26, 2012 | 01:23 PM
jkids's Avatar
NOTE:
NOTE:
While mine happens at exactly 30MPH, I'm hopeful this is what it is.
Thanks for bumping this!
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
MaxLvr21
Oct 17, 2015 12:11 PM
REDinLV
Sep 28, 2015 12:31 AM
