Sprung Clutch
Old Dec 16, 2012 | 09:58 PM
rebelhell's Avatar
Sprung Clutch
Okay, I'm replacing my flywheel with a Fidanza and will be needing a sprung clutch. From what I've been reading the 350Z clutch has been used in the past. Here's my problem. There are several part numbers listed for the 350Z clutch and I've seen many people have problems with the fit. The Exedy only lists one part number but it's $750. Can anyone tell me exactly which clutch I should use (hopefully less than $400)?
Old Dec 16, 2012 | 10:48 PM
mightyMax95's Avatar
the only fitment issues i know of are using a 350z flywheel because the timing ring does not align. any z clutch should work just fine.
Old Dec 16, 2012 | 11:38 PM
rebelhell's Avatar
I fully intend on using the Maxima Fidanza Flywheel, it's the clutch that seems to be an issue. Does anyone know which is the right one? Is there a sprung Maxima clutch I would be better off using?
Originally Posted by viperboy
I have a shop that put in a Fidanza LWFW and 350z clutch kit and they claim that the 350z pressure plate is hitting the trans. They said they need to shave the trans where it is hitting about 1/8 of an inch. I never heard of anyone else having this problem. Is this uncommon or is there something that can be done?? Thanks!
Originally Posted by droobie
I bought the 350Z clutch from Dave B (30205-CD00B) with the Nissan Maxima TO bearing (30502-41U20) and the Flywheel from UltraRev (Fidanza flywheel).
However, when the tech installed the new clutch, they said they heard pinging and then when they took it back apart, they found the bell housing was scraped up because the pressure plate is rubbing up against it and eating away at it.
DaveB isn't around on the weekends (tried calling) so I'm going to call there on Mon.
However, anyone heard of this or run into this problem in the meantime? Maybe it's the wrong Pressure Plate/cover assm in the box?
Old Dec 17, 2012 | 07:55 AM
MaxinO2's Avatar
I'm ordering the clutch combo from JWT today, its an Exedy clutch modified a bit with the Fidanza flywheel.. I believe its sprung and they will offer you a little deal if you get both, just ask.
Old Dec 17, 2012 | 08:37 AM
well, i have a '06 altima flywheel (i'm 6spd) which is the same as the Maxima's and am using an '03 350z clutch and pressure plate. i'm not sure what happened during those installs but mine is working just fine. the engine on the other hand... lol
Old Dec 17, 2012 | 09:43 AM
rebelhell's Avatar
Can you verify this when you receive it and let me know? They don't list a clutch for the 5.5 Max on their website.
Old Dec 17, 2012 | 05:40 PM
MaxinO2's Avatar
I just ordered that combo, should be here thursday.. They don't list it on there website, you have to call.. I'll keep an update
I was wrong about the clutch being Exedy, I'm not even sure what he told me over the phone today, I was too busy with work to get him to repeat it.
Old Dec 17, 2012 | 07:05 PM
rebelhell's Avatar
Very fast response from JWT!
If you wish to upgrade to one of our JWT performance clutch sets, these have a sprung hub design and work nicely with the JWT low inertia flywheel.
LALT2-NF000 Billet aluminum flywheel 15lbs, fits 02+ Maxima, $450.00
LSER2-NC000 JWT performance clutch/disc $299.00 For 2002-2006 Maxima/Altima V6, has 900kg clamping force (use this for 400hp or less)
L3503-NC000 Hi-Performance clutch kit (pressure plate and disc,) 1200kg clamping force fits 2002+ Maxima with 3.5L engine $485.00 (use this for over 400+ hp up to 600hp potential)
Old Dec 18, 2012 | 07:29 PM
rebelhell's Avatar
Originally Posted by supra11
I have a 350z clutch kit 03-05 for my 2003 maxima, if you are interested I will sell new in box for $275 shipped, you might need to buy a clutch release bearing fit specific for maxima its like $50
I appreciate the offer but I think I'm going to go with the JWT clutch.
user 11122324
42
Jul 18, 2022 03:35 PM
Mar 12, 2020 12:06 AM
spencerwh1
Jun 30, 2016 05:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
carlosvq30
Sep 26, 2015 09:44 AM
