Ecu removal
Old Jan 2, 2013 | 05:25 PM
celestialking23's Avatar
Ecu removal
I have a 5.0 gen max and I'm trying to remove the ECU. Found the link in the stickies only to be redirected repeatedly to the ECU Resetting link: http://forums.maxima.org/5th-generat...tting-ecu.html
How did anyone get to the four screws on the ecu? I lost a phillips bit to the carpet and I am pissed. Help please.
Old Jan 2, 2013 | 07:10 PM
tosheto's Avatar
I have a 5th gen and have taken the ECU out before. I decided to take the two bolts on the ECU bracket off and take out the whole thing together. The 2 bolts are towards the rear of the car and you will need to get all the wiring off from the top of it. Hope that helps. It is very tricky
Old Jan 2, 2013 | 07:22 PM
Success
Fitting my 6'4 frame into the driverside floor area (via fetal position) I was able to see the 10 mm bolts and go to work from there. Aside from that, the ecu removal link in the stickies is STILL bad. It redirects to the resetting ecu link. Someone appears to be sleeping on the job
Old Jan 2, 2013 | 07:31 PM
Toshetoooooo!!!!!
Had an Akira moment there. Thanks for the response. I found out about those bolts about 45 min ago and it was not a pretty site. I greatly appreciate your help, because I thought I was going to get some of those responses referring to the stickies.
Old Jan 2, 2013 | 07:44 PM
Tosheto, did you cut those tie down straps? I try to keep everything in the car intact. After this debacle, I don't think I want to put the two bolts back in. Just slap those black panels back on both sides. I managed to get the four screws off of the bracket without moving the wiring harness. Definitely sucked though.
Old Jan 3, 2013 | 12:56 PM
tosheto's Avatar
I might have cut a couple. You can use pliers and take them off. But if you got the 4 screws out you can just slide out the ECU. I I could not get to the 4 screws that's why I took the 2 bolts off and took out the whole thing with the bracket.
Old Jan 3, 2013 | 01:30 PM
Gotcha
Old Jan 3, 2013 | 01:55 PM
Rods03Max619's Avatar
Glad you figured it out was your ECU bad.....
Old Jan 3, 2013 | 02:28 PM
No, wasn't the ecu
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
