Replaced a few things but front end still thumps
Old Jan 11, 2013 | 08:27 PM
wasdpp13's Avatar
Hey guys I have replaced
1. Struts
2. Struts mounts
3. Sway Bar Endlinks
4. All four motor mounts
Here is my info for the car
Locationg: Arizona
mileage: 155k
Still running super strong
And my thump is still there (especially front right) . The weird thing is that my thump sound doesn't appear when I am on highway and smooth road. It only appear when I am in city especially when the speed is around 15-40 mph (uneven road). Even when I am sitting in the passenger side and putting my feet on the floor I can slightly feel the thump.
I also notice when idle (stationary), I turn my steering wheel all the way to the right(only right) then turn back a little bit to the left it makes a cluck (not thump its a clunk) sound. Could that be the reason why the thump sound exist?
I know my outer tie rod is bad (my mechanics said its working fine) but could that make a thumping sound?
My sway bar bushing look just fine, could it be shot?
Trying to fix the right thing to save money
Totally repair costed me alot already, but the noise is getting very annoying (must get it out!).
Any suggestion would be great! THANKS!
Old Jan 11, 2013 | 08:43 PM
MaxinO2's Avatar
This sounds a little familiar but I haven't figured it out for myself.. It's a fairly new clunking sound on my left side that I haven't figured out. My thought were possibly a bad ball joint, control arms, or motor mounts.
Old Jan 11, 2013 | 09:27 PM
wasdpp13's Avatar
But I have changed all four mounts already..... I just changed the endlinks today and it did nothing at all...
Old Jan 11, 2013 | 09:39 PM
Pearl93VE's Avatar
I can has?
How is the wheel bearing over there? Did you try to see if the spindle had any play when you had the wheel off?
Ball Joints...
CV axle...
Old Jan 11, 2013 | 09:41 PM
wasdpp13's Avatar
Could also be CV axle
There is alittle play with the shaking 6-12 direction. Just a little... Isn't a bad wheel bearing would just make sound?
Old Jan 12, 2013 | 05:18 AM
Rochester's Avatar
That's a very familiar description. I had that situation for a while... it was rare, and intermittent. But when it happened, there was such a WTF moment. Particularly because it was happening in the driveway. I had to crank the wheel far to the right in order to get the clearance to back into my garage (because the turning radius on the Maxima SUCKS! /rant). Every once in a while I'd go to the full extent, and when turning the wheel back and backing up... Clunk!
After new tie-rod ends, problem solved.
Old Jan 12, 2013 | 07:45 AM
ATL's Avatar
ATL
Play from 6-12 is prob either balljoints or hub. 3-9 is usually tie rod ends
Old Jan 12, 2013 | 07:55 AM
quick-e's Avatar
I just replaced my sway bar end links yesterday and got rid of 70% of my noise. I do need strut mounts too. So if you haven't done those yet I would replace them. It is 2 bolts each side and about 60 bucks for both. Again only if you haven't. Struts mount give you a deeper tone and sway bar in links are more of a light metal tingy sound. Mine were sounding like a rattle and vibration all in one. Heard them big time at lower speeds like under 60.
Old Jan 12, 2013 | 10:00 AM
noahrexion's Avatar
replace your tie rods
Old Jan 12, 2013 | 02:16 PM
wasdpp13's Avatar
Well I have replaced the struts and strut mount plus the end links the noise is still there.....
Hope your get cured after changing the struts...
Does a bad hub make thump noise? I thought it just makes a humming noise
Old Jan 13, 2013 | 08:27 PM
jd87sep's Avatar
Lower control arm bushing? These tend to go fast especially with power steering leaks.
Old Jan 13, 2013 | 08:37 PM
MAXC's Avatar
Take a look at the steering rack bushings. Take a long screw driver or pry bar and put it in between the rack and k-frame. The rack should not move. If it does then the rack bushings are shot. This could be the source of your clunking sound. Report back your findings....
Old Jan 14, 2013 | 04:02 PM
wasdpp13's Avatar
One of the shops told me to change the low control arm, but it is so expansive I don't wanna really waste money on something that isnt broken. Mean while, the other shops told me the lower control arm are still good nothing bad.
Finally, after half year of rattle, clunking and thump sound the is finally GONE.
It was the piston rod nut that wasn't tight! After tighting it, the noise went away!!!!!!
All the parts I have replaced are crucial to cure any noise!
But here is the problem, do you guys know what is the best torque for the piston rod nut? I searched the forum that people would say from 20-60 ft/lb?
Where is the k-frame?? still wanna know if my bushing is bad no not...
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
Samedi
Aug 12, 2015 01:54 AM
kirkhilles
Aug 8, 2015 10:53 AM
laparka66
Aug 6, 2015 09:36 AM
