Bad lug nut or stud
Old Jan 21, 2013 | 06:22 PM
mclasser's Avatar
Bad lug nut or stud
I had some free time today so I decided to conduct my periodic steering/suspension check on the I35. When I went to remove the wheels, the lug nuts were a royal PITA to unbolt. I had new tires put on not too long ago and those tire jockeys probably torqued the nuts to 200 ft/lbs or something. After much cursing, I was able to get them all off. When putting them back on, one nut in particular gave me great grief. When I went to finger tighten it, it wouldn't thread easily and gave a lot of resistance. I torqued it and all the lug nuts down to 80 ft/lbs and by visual inspection, the nut in question seems flush with the other nuts and is nice-and-tight. But the next time I go to remove the wheel, I fear that nut won't come out or will break the stud it's on. Should I just worry about this later?
Old Jan 21, 2013 | 07:04 PM
DjHackStyle's Avatar
Worry about it later IMO but u should have used antiseize on all lug studs. I do it to all my cars never had a broken stud or hard to remove nuts
Old Jan 21, 2013 | 07:09 PM
ShocknAwe's Avatar
Likely just got some dirt in the threads or something. Clean them off really good next time
Old Jan 21, 2013 | 09:05 PM
Chris Gregg's Avatar
Get Off My Lawn
Don't worry about it now. But, do have a new stud and lugnut in hand for when you pull the tires off next. Although, I've read this is a typical issue (not suggesting rampant, but there have been mention of it over the years) for the 5/5.5 gens. I've never broken a stud in my life until my 2003 and I've broken 5 between both fronts. Only solution I found was to replace every single stud with new oem ones, not expensive and definatley cheaper than having to also replace the lugnuts. I also added anti seize after replacing. No further issues.
How much of this could had been something a shop did in over tightening? Perhaps. But in my experience, the newer studs just seem significantly more brittle than on my 3rd gen.
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
