03 maxima se transmission not shifting to over drive
Old Jan 22, 2013 | 02:51 PM
timmytpd's Avatar
My transmission will not shift into overdrive from third gear. When the car is running, the gear indicator in the dash board is always lit up in third gear. This problem comes and goes. Tomorrow I could start the car and it will shift just fine. Anyone else have this problem or know an inexpensive fix? Thanks
Old Jan 22, 2013 | 03:06 PM
DennisMik's Avatar
Have you checked the transmission oil level? How many miles are on the car? Has the oil been changed recently/ever?
Please don't be starting multiple threads for the same problem.
Old Jan 22, 2013 | 03:53 PM
Rods03Max619's Avatar
Yeah more info would be good....
Old Jan 23, 2013 | 03:31 PM
timmytpd's Avatar
Fluid levels are good. The car has 240,000 miles. The maintenance is kept up. This problem happened to the previous owner about two years ago. He said it fixed itself though. Seems like an electrical problem. Guess I will have to hook it up and get the trouble codes to see what the problem really is.
Old Jan 23, 2013 | 03:33 PM
timmytpd's Avatar
I had a problem with the sunroof previously and learned about resetting the switch on this forum. Figured it wouldn't hurt to ask about a transmission problem. 😃
Old Jan 23, 2013 | 03:53 PM
Child_uv_KoRn's Avatar
Bad *** Newb
This used to be caused by the revolution sensor on the older maximas (which doesn't exist now iirc).
I think it's pretty rare (on 5.5s), but maybe the shift solenoid is crapping out. Or some other sensor LOL. I don't have an auto maxi :P
Old Jan 24, 2013 | 05:48 AM
LongoTE's Avatar
I dont know how the transmission behaves when it throws an error (can our transmissions even throw errors?) so maybe the problem lies in the selector. Im just throwing out ideas. I got a CEL for the park neutral position "PNP" switch, but never came back after it was cleared. If the dash shows "3" selected then maybe the car thinks that "3" is the one selected and disables overdrive like it thinks it should.
Old Jan 24, 2013 | 10:09 AM
DennisMik's Avatar
Auto transmissions can cause the CEL to light. The codes are all in the P07xx category. However, the self diagnostic will give more errors then the CEL codes.
op should run the self diagnostics. Download the auto trans section and start on page 53:
http://boredmder.com/FSMs/Nissan/Maxima/2003/AT.pdf
Old Jan 24, 2013 | 12:04 PM
maximase86's Avatar
I love lamp.
It seems to me the issue might be with the shifter, especially the switch between D and 3. Since the 5.5 gen doesn't have an overdrive button, but instead you move the shifter left and right. There is probably a switch in the shifter assembly that is likely either sticking or going bad. This would likely be the reason your car always indicate it's in third despite it being in D, and it doesn't go into 4th/OD.
I bet that if this switch not working properly might not trip off the A/T check light or SES like either.
S
Old Jan 24, 2013 | 05:12 PM
timmytpd's Avatar
I agree. The problem has to be in the selector. Funny thing is, I got in the car this morning and everything was back to normal. I think I am gonna ride it out and see if it happens again. Thanks for the help everyone!
Lakersallday24
Nov 7, 2024 07:31 PM
maxinout93
Oct 27, 2015 01:29 PM
cmpowell86
Aug 10, 2015 12:35 AM
Tanvirkamal
Aug 5, 2015 01:32 AM
