This is a Nightmare for Maximas =(
Old Jan 25, 2013 | 12:30 PM
  #41
David3267's Avatar
Originally Posted by Catch22
Are those the Trailing arm bushings? There is a really good write up on getting the old fluid ones out somewhere - doing a search should find it. I just did mine and pressed the bushings in using a 1/2" x 5" long threaded bolt. I used big washers and two squares of plywood to press them in - it worked like a charm. The write up says to use a piece of PVC pipe, which would work - but i just used two small blocks of wood inbetween the Trailing arm and the plywood squares (6" x 6").
Nah these are the ES motor mount inserts thanks for the info thoe I'm doing my rear trailing arm bushings in the spring time
Goffery2uned
Aug 21, 2015 09:50 PM
Maxima2010 Prem
Aug 13, 2015 11:34 AM
julian888
Aug 6, 2015 04:39 AM
