P0505 idle control valve
Old Jan 26, 2013 | 03:26 PM
coolwire's Avatar
i have a 2000 maxima and it read P0505 It Starter up good when it cold and i can drive it for 20 mins and start clogged shut stop but then i put it on neutral turn on stay on good but put it on drive and shut stop so is it the P0505 idle control Valve can it be something else beside the valve i hate to buy it thats y im ask before i do thanks guys for reading this
Old Jan 27, 2013 | 10:18 AM
Darkrock's Avatar
This code tends to revolve around the ECU, IACV, and TPS. What occurs is a short in the IACV from coolant leakage (the fix is to bypass the hose) and/or a misaligned TPS that shorts the IACV which shorts the ECU. Get a copy of the FSM and a multimeter for the diagnostic procedure and check under the Engine Management section. If even one pin of the IACV is out of spec it will short the system and throw the code. 1. Pull the IACV check for corrosion (meaning it has leaked coolant) and each pin for resistance and continuity if out of spec or continuity replace the IACV and retune the TPS. I have had brand new IACV at the dealer be out of spec so test any replacement IACV. You MUST retune the TPS or it will short the IACV and continued shorts in the IACV will fry the ECU. That said diagnostic of the systems is straight forward but follow the FSM carefully. Failure to correct the code results in a fried ECU. Go here 1st http://forums.maxima.org/5th-generat...d-seconds.html This is doable and there are alot of threads on this at the ORG. Good Luck! *Also if you have an A/T disconnect the motor mounts.
bumpypickle
Sep 19, 2015 01:07 AM
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
tardrex
Sep 11, 2015 07:35 PM
dcam0326
Sep 7, 2015 07:26 AM
