Misfire help
Misfire help
My wife's 2002 I35 with the 3.5L V6 with 143K on the odometer started misfiring on cylinder 5 on Monday. I replaced all of the spark plugs and the ignition coil on cylinder 5 last night. Then when I started it up, it was worse. It was now misfiring on cylinder 6 (thankfully that is in the front and easy to get to). I swapped the ignition coils between cylinder 6 and cylinder 2 to see if it was the coil. Cylinder 2 started misfiring which means it is the coil and will be replaced today.
I thought it was odd that suddenly after I put everything back together a different coil failed.
Is this just a coincidence or is there another issue that I may be missing?
jmlee44
Oct 2, 2022 02:13 PM
ballerchris510
Sep 11, 2015 05:29 PM
