New fog lights, battery gets weak. Questions
Old Mar 10, 2013 | 09:17 PM
jandk's Avatar
I just install my aftermarket fog lights and I notice it drains my battery gets weak. I installed it the power cable straight to the batter and ground on the frame. For the switch I installed the ground on some metal part under the dash. And for power I tap it on the cigaret fuse under the dash. Oppose to the ACC ignistion And I notice it drains my battery even when the switch is of. What is casusing it to drain when the car is off the light is of.
Bump
Old Mar 11, 2013 | 05:40 PM
DennisMik's Avatar
I don't follow the way you wired things. Why is the switch wired to ground and the cigarette lighter fuse when you have another wire going to the battery?
A simple description of how the wires should be is: battery to fuse, fuse to switch, switch to light bulb, light bulb to ground.
Old Mar 11, 2013 | 05:43 PM
cjandura's Avatar
Lawd Jebus!
Old Mar 11, 2013 | 06:20 PM
jandk's Avatar
Okay before the switch theirs a power wife (red) and a ground wire (black). I connect the power wire to the battery and the black to the frame. Then theirs a relay that has wire that I have to run through my fire wall which is (yellow) connected to the switch then theirs a red wire that suppose to connect to the ACC ignition but I tap it to a Cigarette fuse under the das..then on the switch theirs a black wire that I connect to some metal under the dash. Everything works great..it turns of when I turn it of and turns on when I press the botton. But when off everything is off. Notting on. But it drains my battery..
Is it my battery not holding charge or alternator or bad wireing.
Note. When I take the fuse of the fog lights it starts fine like noting ever happen.
Old Mar 11, 2013 | 08:17 PM
JWatZ's Avatar
This is what I followed when I installed fogs on my Excursion, no issues. http://www.ehow.com/how_8054151_conn...og-lights.html
Hope it helps. btw, ever check for the harnesses for the fogs? Even though your car wasn't equipped with them you may still have the harnesses tuck in there somewhere.
Old Mar 11, 2013 | 08:20 PM
DennisMik's Avatar
Since the battery does not run down when you take the fog light fuse, there is nothing wrong with your battery or alternator. You somehow have the wire connections messed up.
Since your kit has a relay and a switch, here is a simple diagram of how the wires should be connected. I cannot tell you colors, I would need to see all the pieces in order to do that.
Code:
                            RELAY
   │ BATTERY │  ┌────────┼───    ───┼─────> TO FOG LIGHTS
      │ FUSE │  │                     │
          └─────┘                 │ SWITCH │
                                  TO GROUND
Old Mar 11, 2013 | 08:24 PM
nismopc's Avatar
At first I was concerned...
...then I read.
Old Mar 12, 2013 | 07:52 AM
jandk's Avatar
thanks guys...let me check it out again...and yes theirs a harness for the fog...should i just tap into that..???
Old Mar 12, 2013 | 09:36 AM
BlackThornDemon's Avatar
You should get some OEM fogs, and just plug them in.
Old Mar 12, 2013 | 09:51 AM
foodmanry's Avatar
Da Roller Coaster!
Probably easiest to tap into existing harness. No extra wiring needed.
Old Mar 12, 2013 | 09:57 AM
jandk's Avatar
amma try that this weekend...
vingodine
45
May 21, 2016 12:46 PM
EuroDriver
Sep 14, 2015 06:08 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
98nismomax
Aug 13, 2015 12:44 PM
