Stock Amp Specs?
Old Mar 12, 2013 | 09:27 AM
wolfgangss's Avatar
Stock Amp Specs?
Hey guys, I'm having a hard time finding the specs for the stock amp in my 2003 Nissan Max GLE. I bought the car with a already installed aftermarket radio and when the car is off but the keys in the ignition the sound system is great, then I turn the car on and any bass parts will distort the crap out of the rest of the song (even if the volume is turned down). I know the stock sub isn't the greatest and makes some unpleasant noises but it shouldn't be this bad!
So I'm thinking replacing the radio will help this? Any help is appreciated!
Old Mar 12, 2013 | 10:23 AM
DennisMik's Avatar
It sounds like the car originally had a Bose system in it. Bose runs their system on 2 ohm speakers and when you put in aftermarket stereos, they expect to see 4 or 8 ohm speakers. So the amplifier is being over-driven. You need to have an equalizer between the head unit and the Bose speakers.
Go to the Audio forum (http://forums.maxima.org/audio-electronics-21/) and check out the sticky "The BOSE Radio/Speaker Replacement thread".
Old Mar 12, 2013 | 01:46 PM
wolfgangss's Avatar
Wouldn't I need to replace the factory amp to be able to run an EQ?
Old Mar 12, 2013 | 03:06 PM
DennisMik's Avatar
Calling the unit you need an equalizer is probably the wrong word. I don't know the correct name of the thing. What you need is an impedance matching device that also adjusts the power level.
If you read the audio forum, there are probably brand names and everything else in there.
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
sliptap
Sep 30, 2015 05:57 AM
jaydot901
Sep 29, 2015 01:18 PM
Redfox
Sep 28, 2015 10:41 AM
