Coolant on transmission?
Old Mar 13, 2013 | 07:15 AM
Aviation005's Avatar
2002 3.5
I have just had both coolant bridge gaskets replaced
Now when checking my reservoir, it is on low. it appears to maybe be the head gasket..? from the looks of it. does anyone know of anything else it can be over there? it does not appear to be the gasket that was repaired
thanks
Old Mar 13, 2013 | 07:27 AM
02pearlmax's Avatar
upper radiator hose? heater hoses? throttle body coolant lines? cracked radiator?
Old Mar 13, 2013 | 08:13 AM
sprocketser's Avatar
Also tighten your valve covers & see what s going on after , do you have some leaks on the ground .
Old Mar 13, 2013 | 10:00 AM
foodmanry's Avatar
Da Roller Coaster!
Aside this being Planecrash I'll post some thoughts...
1. Did you check your oil? If it is the head gasket then you will see a milky color in your oil. Also, possible to see some oil in your coolant reservoir, particularly at the top of the coolant if the car has been sitting.
2. I don't understand, does the coolant drip on your transmission? Or you just have low coolant? It isn't clear.
3. If it is just low coolant, go back to #1 and check that first. If #1 seems ok, then get under the car and look for leaks. You can also add more coolant up to the proper level and see if it goes down again.
4. Sometimes..as the air is the system is released you will see the coolant drop a bit. This is quite possibly what happened.
Old Mar 13, 2013 | 11:30 AM
NmexMAX's Avatar
dot dot dot ...
Careful with that. Read the FSM for torque values before snapping bolt heads.
Old Mar 13, 2013 | 02:01 PM
cjandura's Avatar
The is Planecrash were talking about he dont have valve covers remember!they hinder his horsepower along with the pvc system
Old Mar 13, 2013 | 02:04 PM
Fakie J Farkerton's Avatar
OP, you've been missed.
Did you replace your water pump yet?
Old Apr 1, 2013 | 09:52 AM
I couldn't replace it. i recently lost my job and thats why I asked for everyone's opinion. I wanted to know if I should beg and plead to my dad for money before trying to replace it. Before I got an answer my thread was locked.
its too late now anyways, its all sealed back up. My new problem is I have a severe oil leak that left no oil on the dipstick. The connery may be leaking. Above the alternator is soaked. Gonna have my friend mechanic try to fix whatever it is tonight . Ill try to get pics in a few minutes.
the coolant leak I was speaking of was left over coolant from a gasket leak that I recently had replaced. It was from a coolant bridge gasket. I was not aware that coolant does not evaporate.
+1, I snapped one. Its a b to fix. gotta tap and stuff (fixed)
thanks for a tru reply foodmanry
Thanks for the post patchup NmexMAX.
anyways guys ill sum it up quick. Had entire timing job done, dropped upper oil, timing cover. Now after re installation, I noticed a huge oil leak above the alternator, which left no oil on the dipstick.. for idk im guessing 15 miles
anyways I took vids of the leak. the car makes a whining timing tensioner noise and metallic click at idle. im scared to drive it. I need opinions. Do I have low oil pressure due to the leak or did I severely mess something up. Thanks in advance
http://www.youtube.com/watch?v=y9pLI...ature=youtu.be
http://www.youtube.com/watch?v=2r_wM...ature=youtu.be
Old Apr 1, 2013 | 02:57 PM
Hey guys just wanted to post an update, it turns out both cam shaft actuators are severely leaking. Thats what drained my oil pan. Im going to get two new gaskets and install.
I'm hoping that fixes the timing chain issue. The new tensioner seems defective, the chain is loose and clattering at idle..
i bought inner fire parts from ebay, idk if thats the reason or if its due to low oil pressure due to both leaks
any input would be appreciated
Old Apr 1, 2013 | 03:01 PM
Amerikaner83's Avatar
if the new tensioner is not tensioning, you will still have timing chain issues. Find the kit (the thing is posted here somewhere on the org) and order a new tensioner and guide kit from nissan
Old Apr 1, 2013 | 03:44 PM
id love to bro, but I have no job and $100 for the next two weeks until unemployment kicks in. Im worried my water pump is now more damaged. the clatter may be from the chain skipping on its sprocket (it was already visibly worn )
im slowing giving up
Old Apr 1, 2013 | 04:55 PM
cjandura's Avatar
Kit is in the 6th gen section and try to buy the tool they have in the tsb to help you
Old Apr 1, 2013 | 07:09 PM
Chris Gregg's Avatar
Get Off My Lawn
Money or not, this is what has to be done to properly fix the issue. If no funds at the moment, the only option is to let the car sit. To try and make due will only result in greater damage to the car and greater potential for a brain aneurism by you.
Old Apr 1, 2013 | 08:37 PM
I am goint to have both VTC solenoids or whatever regasketed. I think the tensioner is loose due to both sides leaking. they are both high pressure from what my buddy says. Thats just my idea tho.. chain is deff clanking..
Old Apr 2, 2013 | 04:52 AM
Greeny's Avatar
¯\(°_o)/¯
Bullcrap, you got an answer, you were told to replace the w/p...which is what you should have done..but you didn't..now it's all sealed back up...nice work there bud...
Here's the problem with your threads, you get GOOD advice each time you post, but you ignore it...giving you advice is completely pointless, because you are already going to do what you have in your pea brain head before you even post the thread...
Old Apr 2, 2013 | 05:11 AM
Old Apr 2, 2013 | 06:48 AM
did you not believe my reason why i didnt replace the pump? no you didnt so SHUT THE **** UP.
you come in here and judge me, **** you. I hope Karma kicks your *** you little piece of scum
Old Apr 2, 2013 | 06:50 AM
...and once again in before the lock
Old Apr 2, 2013 | 06:51 AM
NmexMAX's Avatar
dot dot dot ...
He made an extremely valid point.
Old Apr 2, 2013 | 01:55 PM
Greeny's Avatar
¯\(°_o)/¯
Stop being a little drama queen
Hopefully one day you will start taking advice given, that YOU asked for..Not ignore it because it isn't the answer you were wanting to hear....
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
Pied
Sep 26, 2015 03:29 PM
