High Flow Cats & Emissions
Old Mar 14, 2013 | 11:27 AM
viking89's Avatar
Sup boys,
I've recently thrown a Warpspeed Y-Pipe on my 00 5spd SE, along with an intake and SRS catback. I just picked up the car this year and I've just got a gut feeling that I might not pass my first emissions test.
I've been thinking of adding a fast cat to my set up and I've got a few questions.
Would a new fast cat be worse/better at filtering emissions than a working OEM cat? Because they seem to be more focused on performance than emissions. I'm wondering if I could put a new fast cat on now before I even try for emissions to be safe or wait to see whether or not I fail with my current OEM one.
Also, how much of a difference in sound/hp gains would I expect just by subbing in the fast cat to my current set up? It's already about as loud as I can handle without feeling like a douche during DD
Thanks for any help!
Old Mar 14, 2013 | 11:38 AM
jesseroscoe's Avatar
Where are you located? I take it by your questions about catalyst efficiency that your emissions test includes a sniffer test? If not, is your SES/CEL on?
Amerikaner83's Avatar
iirc, high flow cats don't offer much performance gain.
Even with a warpspeed Y pipe you're going to pass emissions just fine and dandy, unless you're throwing a code. Just make sure the car warms up before you go and test.
Old Mar 14, 2013 | 11:39 AM
NmexMAX's Avatar
dot dot dot ...
Your pre-cats and main cat are still there, whether it be a FC or not, you'll be fine. People have been known to pass with only the fast cat, and full headers.
OEM cat to FC sounds and gains will be, IMO, minimal/negligible.
Old Mar 14, 2013 | 11:40 AM
Not necessarily. If he's FED spec his precats are gone.
Old Mar 14, 2013 | 12:26 PM
5aprilc's Avatar
Very good point.
OP, are you Fed or Cali emissions?
Also, Warpspeed makes a heavy loaded cat if your concerned about passing emissions.
Old Mar 14, 2013 | 12:38 PM
viking89's Avatar
I'm in Ontario, Canada, and I'm not even sure if there's a sniffer test as I've never been through emissions testing before (first car, first year). No CEL/SES
I'm Fed spec so both of my precats are gone which is why I'm concerned. I know warming up the car is supposed to let the main cat take care of everything but I just feel like my cat may be clogged or messed up cause most of the original exhaust system was rusted/turning-to-garbage so it makes me question the OEM cat as well.
My mechanic suggested a high flow cat to open up the last link in the exhaust chain (excluding headers), but now that you guys are telling me sound/hp gains are minimal at best I'm starting to consider the heavy loaded cat as an option instead. Would a heavy loaded cat actually cause me to LOSE performance over OEM?
If fast cats only add negligible performance how is there even a market for them?
Old Mar 14, 2013 | 12:50 PM
one word: MARKETING.
Honestly...I wouldn't worry about it. Just keep filling the gas tank with premium and keep up with the maintenance. Drive for at least 30 mins before the test, and you'll be FINE. They may not even have teh sniffer test...and if not, then all they do is plug into your OBD port and scan. No big deal whatsoever.
edit - I did a google search for "emissions tsting, ontario canada" and look what I found:
The Drive Clean test has changed
As of January 1, 2013, the new test reads your car’s computer history to see if your vehicle meets emissions standards.
http://www.ene.gov.on.ca/environment...lean/index.htm
So in other words....IF YOU'RE NOT GETTING A CHECK ENGINE LIGHT, YOU'RE FINE.
Old Mar 14, 2013 | 12:56 PM
more from the Great White North:
http://www.ene.gov.on.ca/environment...OD_102286.html
On-board diagnostic computers became standard in Canadian light-duty vehicles in 1998. Drive Clean will continue to use a tailpipe test for light-duty vehicles from 1988 to 1997 model years to ensure that grossly polluting older vehicles are identified and repaired. Heavier light-duty SUVs or pickup trucks (3,856 – 4,500 kg) of model years 1988 to 2006 will also receive a tailpipe test as they are not equipped with OBD technology.
Since you have a 2000, you're ODB.
Be happy with this change...looks like they used to sniffer test, now they're not
Old Mar 14, 2013 | 12:59 PM
viking89's Avatar
Word! Thats what I like to hear.
How much do you wanna bet a engine light springs up randomly during the 30 mins I'm driving around before the test
Old Mar 14, 2013 | 01:00 PM
don't talk like that.
Old Mar 14, 2013 | 01:24 PM
Since you don't have to worry about the sniffer test and you just recently got the car, the only thing left to do is just make sure your SES light actually works. Make sure that it comes on with all the other lights when you first turn the key (just to make sure the previous owner wasn't hiding something from you). I'm dealing with removing rusty exhaust right now down here in the south eastern US, I can't imagine what the rust looks like up there...
TallTom
57
Oct 14, 2025 05:16 PM
Apr 16, 2020 05:15 AM
maxinout93
Oct 31, 2015 02:04 AM
