reverse issue
Old Mar 15, 2013 | 08:46 AM
uptownsamcv's Avatar
reverse issue
i put my transmission back in, cant driv emy car yet though cause the pan is off. i have a 02 with a 6 speed and it wont seem to go into reverse. reverse lockout on the shifter works and it goes all the way to the right but when i go to move the lever into reverse its just jammed.
when reinstalling my transmission i broke the sensor on the back of it, could this be the issue?
Old Mar 17, 2013 | 09:09 AM
anyone??
Old Mar 17, 2013 | 04:37 PM
MaxFiyah's Avatar
Happens to me sometimes a transmission expert told me its normal when the car is cold just put in first to get the tranny moving then reverse but in your situation idk
Old Mar 17, 2013 | 05:09 PM
the car has been sitting since late december. ichanged the clutch and now im waiting for the tranny harness and neutral switch. also doing the oil pan and gutting the cats. thats whats left till I can drive it again..
Old Mar 17, 2013 | 05:19 PM
MaxFiyah's Avatar
o goodluck man! i hate mechanical problems right now i need to bleed my slave cylinder and since its rusted ima replace it and bleed it then
Old Jun 21, 2013 | 10:00 PM
dddanielek's Avatar
Just wondering if you have fixed the problem? I just went inside my MT6 and replaced noisy input shaft bearing and assembled everything and all 6 Forward gears engage by hand by moving the forks EXCEPT the reverse? WTF? It seems like the when i remove the sping and the check ***** it works fine?
Old Jun 22, 2013 | 10:02 PM
for me it was a plastic bushing that I lost that goes on the tranny lever, the one that isn't modded for the shifter mod.
on mine the side to side selector was off so reverse was hard to go in and I had to pull the reverse lockout and go over a bit more to catch 5th and 6th. dealer didn't have it so I ended up getting a bronze bushing off ebay.
http://www.ebay.com/itm/290761296573...84.m1439.l2649
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
Lilfatz301
Sep 18, 2015 08:06 AM
lrb6805
Sep 17, 2015 04:49 PM
minsbang
Sep 11, 2015 08:48 PM
