Pulls to the left, some clanking ... D2 coilovers
Old Mar 20, 2013 | 11:37 AM
dakota510's Avatar
well i just got a new maxima with d2 coilovers. got 4 new tires all around and went to get it aligned just to be safe. but heres the delima
say when im at a stoplight and i turn right then start driving it will pull to the right, but if i turn to the left and then drive it will drive pretty straight maybe a little pull to the left? it also makes a clanking noise while turning the wheel usually in reverse.
this is very annoying, and i dont want my tires to wear abnormally from this. i can deal with it but my wallet cant. lol
trax tires said everything in the front felt tight and nothing looked worn.
any ideas/suggestions? should i even worry about it??
thanks!
Old Mar 20, 2013 | 11:48 AM
FastnFuriousMax's Avatar
are you saying it doesn't turn left or that after a left turn and you drive straight it pulls to the left slighty and you have to correct it with the steering wheel?
Old Mar 20, 2013 | 11:53 AM
dakota510's Avatar
im saying that if make a left or right turn, the car will pull the way i last turned the wheel.
Old Mar 20, 2013 | 12:13 PM
You have a steering issue.
Old Mar 20, 2013 | 12:15 PM
dakota510's Avatar
since its alligned and the tow is right the tires should wear normally right??? and what kind of steering issue?? tie rod?
Old Mar 20, 2013 | 12:22 PM
Amerikaner83's Avatar
I worry about the clicking noise...sounds like a CV issue.
Old Mar 20, 2013 | 12:25 PM
ateick's Avatar
Sounds like you may have a front coilover that is binding on one side. The strut/coilover should turn freely inside the strut tower. If a strut mount bearing is bad the coilover may not turn freely and will actually load up with energy as you turn the steering wheel. Then when you release the steering wheel it will pull back in the opposite direction to release that built up load.
Old Mar 20, 2013 | 12:26 PM
dakota510's Avatar
its only in reverse. sound like a metal ting
how can i figure which one???
Old Mar 20, 2013 | 01:17 PM
ateick's Avatar
On a lift or on the ground have someone turn the steering wheel side to side. Watch the spring on both sides. If one of them seems to be sticking and doesn't move smoothly that would be the one.
Old Mar 20, 2013 | 01:41 PM
you should hear it move if it binds up that much and then releases right?
Old Mar 20, 2013 | 01:58 PM
ateick's Avatar
Yes I would have thought there would have been more noise noticed if this proves to be the issue. He did note a lot of noise in reverse however.
OP you've probably already looked at this but make sure the 3 nuts on each strut tower under the hood are tight - like 40 ft-lbs tight.
Old Mar 20, 2013 | 02:48 PM
5aprilc's Avatar
My car made a similar noise, turned out to be a broken exhaust hanger. The noise was the most present when in reverse.
Old Mar 20, 2013 | 03:39 PM
dakota510's Avatar
yeah the 3 nuts are tight. i did notice while turning the wheels, the left strut ( when looking from the driver seat) turns while the other doesnt really??? whats this mean
Old Mar 20, 2013 | 04:16 PM
your strut bearing is gone?
Old Mar 20, 2013 | 04:24 PM
dakota510's Avatar
Im not sure? They are both suppsed to turn with the wheels right?
Old Mar 20, 2013 | 07:22 PM
foodmanry's Avatar
Da Roller Coaster!
Hmmm...it sounds like two separate issues. Let's focus on the front end steering problem.
1. Is it worse under acceleration?
2. Do you feel a pull or loss of control at any point? Such as a severe pull.
3. Is the steering loose?
4. Any sounds going over bumps?
5. Difference in the feeling between high or low speed turns? Do you feel it during low speed turns?
It sounds like the coilovers, but I wouldn't say they are the bearing unless he is hearing clunking noises. It could be an install problem with the coilovers.
OP...you bought the Maxima with the coilovers already installed?
Old Mar 21, 2013 | 10:01 AM
dakota510's Avatar
yes they were previously installed. and none of the above im going to put it on a rack and see whats going on i will keep yall posted
Old Apr 26, 2013 | 12:32 PM
dakota510's Avatar
took it to two places. they set the tow and camber and they say they cannot figure out why it will pull to the last way it was turned......but the popping was front one of the coilover springs binding when i backup up. that went away. should i worry about this pulling issue or just leave it alone. he said it wouldnt wear my tires wrong.
James92SE
142
Jan 2, 2024 09:23 AM
NismoMaxi02
Oct 4, 2015 09:09 PM
BrandonCause
Sep 14, 2015 10:41 PM
