tie rod replacement question?
Old Mar 28, 2013 | 04:51 PM
gotendbz1's Avatar
I will be replacing the ball joint and tie rod end outer on the driver side, should I replace the tie rod end on the passenger side also?
same goes for the ball joint also?
Old Mar 28, 2013 | 05:23 PM
slo-ryde's Avatar
Do both, and do wheel alignment once.
If you're asking about the outer tie rod I would suggest doing both of them at the same time. You'll need to have the toe-in adjusted after replacing one or both, might as well do them both. The same would be true for the lower ball joint if that's what you're referring to.
Old Mar 28, 2013 | 05:42 PM
gotendbz1's Avatar
yes thanks,
also moog good choice for oem replacement?
Old Mar 28, 2013 | 05:55 PM
slo-ryde's Avatar
yes thanks,
Yeah, Moog would be great.
rbuswell
Nov 17, 2016 04:54 AM
kingw323
20
Oct 21, 2015 08:36 AM
homeyclaus
Sep 3, 2015 06:15 PM
scarletsosa
Aug 17, 2015 09:09 PM
classymax420
Aug 6, 2015 06:35 PM
