Idle stall problem?
Old Mar 30, 2013 | 06:18 PM
CDing95's Avatar
Idle stall problem?
I have a 5th gen maxima se manual. Lately I have had a problem with it stalling when I let off the gas and brake while in neutral. I've tried cleaning the throttle body and fuel injector cleaner. Any ideas?
Old Mar 31, 2013 | 11:18 AM
Aviation005's Avatar
check for a vacuum leak (cracked rubber hose)
your fuel pump may be failing
Old Mar 31, 2013 | 12:26 PM
T_Behr904's Avatar
Any SES codes?
Old Mar 31, 2013 | 03:07 PM
slo-ryde's Avatar
Just had to deal with this problem on the wife's 2001 Camry, turned out the idle control valve was full of carbon and causing the valve to stick in the open position. I'm pretty sure our Maximas use one too. Might be a good idea to make sure it's clean and moves freely. For some reason this failure never set any codes on the Camry.
Old Mar 31, 2013 | 03:30 PM
cjandura's Avatar
What year? And when you cleaned the tb did you touch the plate also if you u plugged it you may need a relearn
Old Apr 1, 2013 | 06:36 AM
CDing95's Avatar
Any SES codes?
No, there are no SES codes for it.
Old Apr 1, 2013 | 06:39 AM
CDing95's Avatar
It's a 2000. And I don't think I don't think I touched the plate when I cleaned it.
Old Apr 2, 2013 | 08:10 PM
metalpiotr's Avatar
03 Maxima, 6spd
Idle Air Control Valve?
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
97_GXE
Sep 15, 2015 06:47 AM
