wha is an autmagic????
Old Jan 13, 2002 | 07:04 PM
  #41
Greg's2kGLE's Avatar
Originally posted by ehughes
My 2k2 seems to do better when I shift just before redline, more so from 2-3 though. The problem is when "sawing the lever" or manually shifting an auto, I find that when you shift, the tranny takes to d@mn long to go to the next gear. You almost need a 200 rpm buffer zone when you shift. This delay is even more pronounced at higher rpms. Athough, once the VB Mod is done, things will hopefully be different.
Manually shifting an auto doesn't actually sihft the gears like a true manual does. When you shift into a different gear, you are telling the computer what gear to shift it, not shifting actual gears. Put it this way, you are suggesting that the computer shifts into "this" gear. Hope that is clear
Old Jan 13, 2002 | 07:08 PM
  #42
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Originally posted by Greg's2kGLE
So basically when the curves intersec (if they do) that's where you want to shift becuase if you go any further, there will be less power, correct??
You got it
Old Jan 13, 2002 | 07:10 PM
  #43
Originally posted by SteVTEC
You got it
Yippe!!
Old Jan 13, 2002 | 07:20 PM
  #44
SteVTEC's Avatar
An older Mustang GT makes peak power at around 4700rpm yet has a redline of 6000rpm. You actually get the best performance in the Mustang if you shift at around 5500rpm. This is because the engine wheezes for breathe at higher RPM's and can't make any power.
The Subaru WRX makes peak power at 6000rpm but has a redline of 7000rpm. This is because the factory turbo boost controller opens up the wastegate and drops the boost pressure to avoid over-spinning the turbo (a little mod can fix that though ) So on this engine you end up getting the best performance if you shift at around 6500rpm on the 2-3, 3-4, and 4-5.
The 5th Gen Maxima makes peak power at 6400rpm and has a redline of 6500 rpm (I think) so you just shift that puppy at redline all the time since the engine is making full power all the way up to the top and doesn't fall off. That's why you automagic guys get screwed over with that crappy 6000rpm shift point. You have to manually shift it and time it just right so that it shifts at 6500rpm while also not hitting the rev limiter.
Old Jan 13, 2002 | 08:13 PM
  #45
SkylineGTR's Avatar
my 5th gen shifts at 6300 if i leave it in Drive
too much NOS...
but if the tranny blow out ill
Old Jan 13, 2002 | 08:16 PM
  #46
costcowholesale's Avatar
not anymore now peak power is @ 5900 rpm from the vq3.5
Old Jan 13, 2002 | 08:41 PM
  #47
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
Re: gone in shifty seconds.....
Originally posted by DOHC 30 V6
OK, if you "manually" shift your automagic, (1st gear to redline, 2nd to redline), what makes you think you will be accessing more horsepower?? Your car shifts where it does (under WOT) for a reason - it is the point at which most horsepower can be used most effectively. Redline does not indicate peak horsepower, and in fact, may actually allow the powerband to drop off a bit. Remember, power curves are just that - curves, not straight lines. You dont make more horsepower by using the 1st gear -> redline, and second gear -> redline selector, you just run your engine at a higher RPM. Just turn off your O/D button, the tranny will do the rest. Hope this helps!
actually in 2k and 2k1's the peak hp is 6400rpms but it shifts at 6K so you are missing out on hp.
Old Jan 13, 2002 | 08:45 PM
  #48
SteVTEC's Avatar
Here's what CarTest2000 says for a 2k2 6spd for Optimal shift points:
1-2 @ 6600rpm (40 mph)
2-3 @ 6520rpm (64 mph)
3-4 @ 6380rpm (88 mph)
4-5 @ 6340rpm (116 mph)
5-6 @ 6330rpm (152 mph)
It gives a maximum speed of 149 mph though, so it looks like you'll get top speed in 5th gear at redline on a 2k2 6spd and 6th gear is just an econo gear (0.612:1).
Old Jan 13, 2002 | 08:50 PM
  #49
ya it feels like there are up there not the 6100rpms like dave B says. but redline once you get going is not the best i think. esp 3-4 and 4-5 right around 6400 is where it feels good.
Old Jan 13, 2002 | 09:48 PM
  #50
SteVTEC's Avatar
Here's the plot for the 2k2.
2k2 6spd Drive Power Curves
Old Jan 13, 2002 | 09:50 PM
  #51
big red X
Old Jan 13, 2002 | 09:52 PM
  #52
irvine78's Avatar
Originally posted by MichaelAE
No, I agree with you off the blocks...as long as you are WOT, O/D does not come into play...particularly not in play since it only engages in D4.
yup...
and i don't think anyone can shift faster and better than the computer..if you do..then mad props goes to you...
it's just that even if you just dropped the hammer and go WOT..the computer won't shift up until u hit the rev-limiter or near the redline..so..i don't know if ****ing manually with auto really helps..but then again, i don't have one so i can't say for sure..
Old Jan 13, 2002 | 10:09 PM
  #53
DOHC 30 V6
My head hurts now.....
I think me and Greg are gonna have to race and see who does better, his manual shifts, or my reliance on the autotranny's telepathy
Old Jan 13, 2002 | 10:27 PM
  #54
irvine78's Avatar
Re: My head hurts now.....
and that would be one of the most anticipated race ever!! do it and let us know..may the best win..
Old Jan 13, 2002 | 10:42 PM
  #55
Y2KevSE's Avatar
Rice Boy in Denial =)
Originally posted by irvine78
Kev invented this vocabulary to make himself feel better..
Old Jan 13, 2002 | 10:44 PM
  #56
irvine78's Avatar
Originally posted by Y2KevSE
u know it's true..
Old Jan 13, 2002 | 10:47 PM
  #57
Y2KevSE's Avatar
u know it's true..
Don't hate.
Old Jan 13, 2002 | 10:48 PM
  #58
irvine78's Avatar
Don't hate.
oh my..u took my words right out of my mouth!!
Old Jan 13, 2002 | 10:51 PM
  #59
Y2KevSE's Avatar
So you get any new mods lately?
Old Jan 13, 2002 | 10:58 PM
  #60
irvine78's Avatar
yeah..lost about 15 lbs!! and worn out clutch...
Old Jan 13, 2002 | 11:00 PM
  #61
Y2KevSE's Avatar
You went on a diet? No worn out clutches with an auto.
Old Jan 13, 2002 | 11:01 PM
  #62
irvine78's Avatar
no...just stopped working out...got lazy at the end of last year..
and yeah, no worn out clutches with an auto..but no driving fun either..
Old Jan 14, 2002 | 01:14 AM
  #63
SkylineGTR's Avatar
hmm.....careful now....if this continues, i see this gradually turning into a auto vs 5spd war.
Old Jan 14, 2002 | 04:34 AM
  #64
manual shifting on the 2k and 2k1 WILL help because peak HP comes at 6400rpms and the computer shift at 6000 rpms so you are loosing hp range.
Old Jan 14, 2002 | 07:12 AM
  #65
Y2KevSE's Avatar
Irvine78's just jealous... don't mind him. He couldn't fork out the few hundred bucks for an auto.
Old Jan 14, 2002 | 08:36 AM
  #66
Bring it!!
Old Jan 14, 2002 | 10:30 AM
  #67
irvine78's Avatar
only if Kev knew what i went thru to find my car...with 5 speed...
Old Jan 14, 2002 | 11:40 AM
  #68
Y2KevSE's Avatar
Now I know why you smoke.
Stop changing your sig pic on us...
Old Jan 14, 2002 | 11:56 AM
  #69
Y2KevSE's Avatar
Originally posted by yo_its_ok
Wha hee smoak ? I wannaa suumm.
Sig Pic Pwwetty.
He smokes my exhaust gas.
Old Jan 14, 2002 | 12:09 PM
  #70
ehughes's Avatar
I don't think I implied that the auto stick is directly connected to the tranny. Semantics...When you "manually" shift an auto, you choose when the car shifts up or down, regardless of how it happens. All I am saying is that my 2k2 needs Don's VB mod!
Old Jan 14, 2002 | 12:47 PM
  #71
Y2KevSE's Avatar
I'll remember to call upon your services when I get to Gardena.
I can't tell the quality of the gas because I don't have a certain gauge yet. *cough**cough*Tomei*cough**cough*
Old Jan 14, 2002 | 01:08 PM
  #72
irvine78's Avatar
yeah, well..Kev knows he got the SC to beat me...
Old Jan 14, 2002 | 01:16 PM
  #73
Y2KevSE's Avatar
Grr, I'll have a Trackin # in 10 minutes.
Your 10 minutes is up.
Old Jan 14, 2002 | 01:20 PM
  #74
irvine78's Avatar
more gauges, eh? i thought you already had an EGT.
Old Jan 14, 2002 | 01:22 PM
  #75
Y2KevSE's Avatar
I wanted to see how your front spoiler would look in my rear view mirror. I'm sure it looks just as good as it does in the pictures... I have 20/20 vision so don't make me squint too hard to enjoy view.
Old Jan 14, 2002 | 01:23 PM
  #76
Y2KevSE's Avatar
Tomei is easier to use for tuning the S-AFC (also from Hogan).
Old Jan 14, 2002 | 01:45 PM
  #77
Y2KevSE's Avatar
on the phone now with ben from aebs, grr Nathan is gonna be canned, no wonder that F*ck wads been yanking my chain. Anyhow Ben says its going out today, so he told me 30 minutes.
My Altima will beat you both :-)
-Peace
OK, you have 15 minutes left.
We don't waste our gas on Altimas.
Old Jan 14, 2002 | 01:59 PM
  #78
Y2KevSE's Avatar
I bought a SR20DET U13 M/T, it needs a new clutch, and I have N14 driveline sitting at friends shop.
Now I have 10 minutes.
-Watch the clock, as it ticks life away.
Doh! Ummmmm...... we don't race econobox cars.
Old Jan 14, 2002 | 03:55 PM
  #79
Y2KevSE's Avatar
I have more FWHP than j00
Car is Lighter
manual w/ LSD
but, slipping clutch :-(
-Shipping processing, Tracking # in a few.
Got your email. Thanks for handling it.
I know you can have more fwhp than me with that motor. It's scary to imagine such a small car with so much hp. Still, it's an econobox.
Old Jan 15, 2002 | 06:59 AM
  #80
Y2KevSE's Avatar
No wonder the toasted clutch.
Yeah its an econobox, but a total sleeper. It's like a Honda, but the badges say Nissan.
Am I rice ?
No, you're not rice.
Power + sleeper does not equal rice.
