Intake Manifold removal questions...
Old Apr 25, 2013 | 08:16 AM
TallTom's Avatar
Hey all, I want to replace my plugs and have been searching for the easiest way to remove the manifold to get to the rear plugs. I found two different how-to's and they seem to have different methods. Which method do you recommend? My car already has the 6th gen valve cover installed so I just need to access the plugs.
http://www.greghome.com/Greg%27s%20G...eplacement.htm
or
http://vqpower.com/v3/content/2002-2...k-plug-writeup
Also, I am pretty sure that the gasket goes on without sealant but figured I would ask since I am making this thread.
Thanks in advance.
Old Apr 25, 2013 | 08:48 AM
NmexMAX's Avatar
dot dot dot ...
Didn't bother to read either one, but what are the differences in the steps in each?
It's pretty self explanatory, remove cover (if you have one), remove VIAS system, (if you have one) and then remove the IM bolts. Most tricky is the rear bracket holding the IM to the firewall (again, if it's still attached).
You can choose to DC the TB, or, you don't need to, the job can be done with it still attached. First time I did it, I left it plugged being paranoid, but every time after that, I DC'd it electrically and mechanically.
Also there are various misc. connects for EVAP, PVC, etc. Those are also self explanatory.
Just remember what went where.
None of the above items on mine are in tact, so i just remove teh IM bolts, and it comes off within minutes.
Old Apr 25, 2013 | 11:55 AM
Gemner's Avatar
1) disconnect sensors
2) take bolts out
3) remove manifold
4) replace plugs
5) reverse steps 1-3
Old Apr 25, 2013 | 12:08 PM
Mikel81's Avatar
When I got my car I bought new plugs and popped the hood and was like damn this isn't going to be as easy as I thought. I found that first thread in the op and was in disbelief in how many steps it was to change the back 3. Honestly, get the IM gasket and just start taking it off. It was nowhere near as bad as it sounded. I did plugs and valve cover with a friend and it was maybe an hour project, everything went smooth.
Old Apr 25, 2013 | 12:15 PM
TallTom's Avatar
Cool.
Thanks everyone.
Old Apr 25, 2013 | 12:19 PM
NmexMAX's Avatar
dot dot dot ...
If you need a new IM gasket, let me know, I've got one. 2 actually, do you have NWP spacers?
James92SE
142
Jan 2, 2024 09:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
Mahmuth
Sep 17, 2015 11:45 AM
