LMGT4 Rim Offset
Old May 4, 2013 | 01:22 PM
nishfish871's Avatar
LMGT4 Rim Offset
Want to know how much/if it would poke even with a light fender roll. Not looking to run stretched tires. Let's put it this way, I'm a noob when it comes to rims.
Nismo LMGT4
19x8.5 +25 All around
245/35/19
or
19x8.5 +25 front
245/35/19
19X9.5 +30 rear
265/35/19
http://1.bp.blogspot.com/-RMzTlz7V5Q...o___lm_gt4.jpg
Old May 4, 2013 | 01:37 PM
cjandura's Avatar
Nismo LMGT4
245/35/19
or
19x8.5 +25 front
245/35/19
19X9.5 +30 rear
265/35/19
How much are those? And i would do the 8.5 on all 4 corners.i dont like staggered it screws with tire pricing/deals and you caint rotate
Old May 4, 2013 | 01:57 PM
SSJRICH's Avatar
+1 Non staggered. For FWD there is really no point, except for looks I guess. If you had a RWD car then yes staggered set up it ideal to lay down the power at the rear, and to have a quicker turn in for the fronts. But then you can't rotate the tires and you always end up with uneven wear.
Old May 4, 2013 | 02:04 PM
SSJRICH's Avatar
Sorry and for you original question... As I am to assume that your car is slammed as in the pic running 245's at +25 will need a slight fender roll and should be flush to slight poke depending on your suspension setup.
Old May 4, 2013 | 02:24 PM
I wasn't a fan of the staggered setup to begin with. It had more to do with fitment without needing to run a spacer in the back.
Assuming the front is of most concern when you talk about all same size flush/slight poke. Rear will need a spacer to even it with the fronts.
And yes, I know I'd have to raise the car a tid bit.
Old May 6, 2013 | 05:37 AM
bump, want to see if anyone else wants to chime in
Old May 6, 2013 | 07:32 AM
Prophecy99's Avatar
talk to sil SE, he may be able to help you a little, he had these on his 4th gen at one point or another.
nice rim choice by the way, they are one of my all time faves
Old May 6, 2013 | 07:52 AM
Chris Gregg's Avatar
Get Off My Lawn
Someone correct me if I'm wrong, those look like unilug. Wasnt aware Rays did the Nismo rim in unilug.
In any case, my point is that I ran into an issue when considering running spacers on a unilug rim. Because there was no opening/gap between the lug openings on the back side of the rim, I couldn't run a 5-15mm spacer because the lug nuts securing the spacer protruded....so the extra lug nut sticking out needed a place to go. On unilug, the space between lugnut holes is occupied by another hole.
I'd guess you'd have to run the spacer setup with the spacer seperate from the extended studs?
Old May 6, 2013 | 08:39 AM
They aren't unilug but they have the holes there...here's a pic
http://i131.photobucket.com/albums/p...s/photo-29.jpg
Old May 6, 2013 | 09:47 AM
Prophecy99's Avatar
Yeah normal spacers with extended studs wouldn't be a problem
Old May 6, 2013 | 10:10 AM
Get Off My Lawn
Thanks guys. Pic helped a lot.... So indeed it appeara a spacer with built in studs would work.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
mpbclutch33
Sep 21, 2015 01:54 PM
steveyphat
Sep 15, 2015 03:43 PM
0m3nc0w
Sep 11, 2015 05:21 PM
