Creaking sound from suspension/shaking
Old May 9, 2013 | 05:58 PM
RA11325's Avatar
-needs 4 and spring struts I know this, the front right one is the most shot which I believe is where the creaking noise is coming from (refer to sound).
-At around 60 MPH steering wheel beings to shake but not a whole lot.
-When slowing down from 70 MPH or so the steering wheel shakes pretty badly. (Rotors?)
The creaking is the worst when slowly going of bumps, couldn't really find any so the video isn't the greatest demonstration..the best you can hear it is right at the beginning and around 1:20-1:30
Old May 9, 2013 | 07:07 PM
The Maxima's Avatar
Have you tried checking your brakes? I know when mine made this sound it was the sound of the brake components grinding against each other.
Old May 9, 2013 | 07:37 PM
Chris Gregg's Avatar
Get Off My Lawn
These cars are known for suspension issues at a fairly a early stage. if not yet replaced, should inspect the struts, strut bearings, bad spring isolators (rubber things between springs and struts), lower control arms, and hub bearings. Not sure what the source of your noise is, but all the aforementioned will contribute to suspension issues and noises. Tie rod ends and ball joints also seem to have fairly high failure rates at this age.
I would say the vibration is rotors.
Old May 20, 2013 | 12:27 PM
djfrestyl's Avatar
Suspension Yoda
Could also be a bad case of strut mounts or motor mounts.
Are you local to NJ? I do installs for org members.
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
