Cam Position Sensor?
Old May 9, 2013 | 10:31 PM
Y2kMaxima's Avatar
Just happened yesterday, was running perfectly, then at the light on my way home, the engine just turns off. I try to start it back up, it turns on and instantly shut off. I try it a couple more times, car starts but engine is struggling, then the TCS , CEL and Slip light turn on. Wtf right? Anyways, I turn on my emerg. Lights and try to drive home, I try n put my foot down and the engine seems to like choke, atleast that's the way it sounds. It feels like it's being drained, the power goes down and I lose speed, but when I put little gas in the car runs as if it were fine, just slowly. I checked all ignition coils, they all fire, replaced the spark plugs with new ones, and did an audible test on the fuel pump to see whether it was working or not. So I need some help guys, if anyone has an idea shoot it my way, anything helps.
Old May 9, 2013 | 11:04 PM
ill12will8's Avatar
Well I just had the same problem but started right back up and I scanned it and got code P0345
Old May 10, 2013 | 03:17 AM
The Maxima's Avatar
Yep that's your camshaft position sensor. Mine went out about a year ago. It wasn't as bad as yours, but my wouldn't go over 60 and was groaning really loud.
Old May 10, 2013 | 03:51 AM
CauzinDrama's Avatar
try unplugging your mass air flow sensor see if it runs any better in limp mode. I've had my mass air flow sensor go a couple of times and it would show a camshaft sensor code.
Old May 10, 2013 | 06:13 AM
Pilm's Avatar
scan for codes
Old May 10, 2013 | 09:24 AM
ill12will8's Avatar
Which bank is which when it comes to cam sensors?
Old May 11, 2013 | 07:06 PM
Y2kMaxima's Avatar
Yeah I tried that man, still ran the same way so MAF is out of the question. Just went to advance auto to get the codes read but the panzies said they don't go out after 8. Lmao, so I'll just see tomorrow and let you guys know what code I get and if you were correct.
Old May 12, 2013 | 07:23 AM
If the cam sensor is bad make sure you buy a dealer oem one.
Old May 12, 2013 | 05:45 PM
Y2kMaxima's Avatar
Got a P0100, MAF problem guys!
TallTom
57
Oct 14, 2025 05:16 PM
gavin68
Sep 18, 2021 12:36 PM
hayne
Oct 5, 2015 11:53 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
