Searched and still confused
Old May 18, 2013 | 05:02 AM
IceBerg's Avatar
my 2003 maxima has had the codes p0420 and p0430 come on simultaneously i read through post some say o2's others say pre cat .i know this car has 2 precats which would it be? if it were the 02s which would it be.only clear amswer i got from search was it is a very costly repair,btw my mpg sucks since those codes showed up and im worried about damaging my engine as some has claimed to do not sure if its true.Thanks for any help!
Old May 18, 2013 | 06:55 AM
2damax's Avatar
Mileage? It could be pre-cats and o2s. In a perfect world I would replace both depending on mileage. If it is just o2 sensors then you could replace both primaries and see how it goes. That will not be super expensive. Replacing precats is still recommended. In fact, I have no codes and wish I could afford to replace mine.
Old May 18, 2013 | 09:47 AM
IceBerg's Avatar
97k as of right now I did a visual inspection of the precat near the radiator and it is rusted to **** I was wondering if anyone with these codes fixed them
Old May 18, 2013 | 10:04 AM
TallTom's Avatar
I would replace the o2's first for they are cheaper. PreCats + installation can get pricey.
Have you done anything to your car before getting the codes?
Old May 18, 2013 | 01:23 PM
IceBerg's Avatar
I changed the evap solenoid that's about it,I'm thinking of maybe gutting both and get de-foulers to pass emissions
Can i install defoulers without gutting cat?
Old Jul 2, 2013 | 03:33 PM
NmexMAX's Avatar
dot dot dot ...
Old Jul 2, 2013 | 03:34 PM
5aprilc's Avatar
I had both codes, I ended up buying an aftermarket Y pipe and bank 2 precat, along with replacing all the main O2 sensors. Is your car California or Federal emissions?
Old Jul 2, 2013 | 04:53 PM
rebelhell's Avatar
It's a 2003, there is no seperate Cali/Fed spec exhaust.
Old Jul 5, 2013 | 08:16 AM
IceBerg's Avatar
Thanks guys i bought my defoulers today plan on doing it this weekend will update its federal btw
Does anyone have a specific write up idk what im doing wrong 1.i have two defoulers for each o2 sensor my problem is when i thread one into the other it raises the o2 sensor on the precat to high so i cant get the sensor into the defouler with the little space between the defouler and motor
Old Jul 6, 2013 | 08:25 AM
cjandura's Avatar
did you drill the one out?
Old Jul 6, 2013 | 08:30 AM
cjandura's Avatar
http://vibrantperformance.com/catalo...sort=2a&page=2
Old Jul 6, 2013 | 09:28 AM
IceBerg's Avatar
yes i drilled one and screwed it into the other everything threads in fine its just not enough room to thread the o2 sensor
Old Jul 6, 2013 | 09:52 AM
TunerMaxima3000's Avatar
This. These are the ones to buy, not the cheap straight ones.
Also, putting non-foulers in is just masking a problem. That's fine if the O2 sensors are at fault, but if it's precats that are bad, you are only shooting yourself in the foot by not addressing it.
If you are just ignoring the problem, you might as well ignore the light, it's cheaper and easier, lol.
If the issue is the precats you should gut them out at a minimum. It's not good for the engine to have plugged/deteriorated precats, the engine will wear/fail prematurely.
Old Jul 7, 2013 | 11:48 AM
IceBerg's Avatar
Oh ok so the straight ones are just for the other cats ,i got the p0420 after using techron so i was thinking maybe the cat is clogged .I was thinking of trying cataclean
Old Jul 7, 2013 | 02:26 PM
Child_uv_KoRn's Avatar
Bad *** Newb
There is no cleaning them. They clog and disintegrate. Fuel additives just speed up by making them hotter.
Old Jul 7, 2013 | 02:49 PM
IceBerg's Avatar
its actually not a fuel additive according to their website
Old Jul 7, 2013 | 06:55 PM
rebelhell's Avatar
If you already know what you're doing then why ask?
Old Jul 9, 2013 | 11:14 AM
IceBerg's Avatar
Just needed some insight as to how others have dealt with this code
Old Jul 9, 2013 | 11:53 AM
TallTom's Avatar
the non-foulers are supposed to be for the bungs after the precats.
Old Jul 9, 2013 | 12:18 PM
cjandura's Avatar
Isally when you use some kind of "snake oil" in your fuel and you get a cat or o2 code after its due to the o2 sensor being on its way out.its usally so worn and dirty it can no longer hold it tolerances with the readings.
Sent from my iPhone using MaximaOrg
Old Jul 9, 2013 | 12:34 PM
foodmanry's Avatar
Da Roller Coaster!
Gut both pre-cats and install the non-foulers. Issue will be solved and the car will run fine.
Old Jul 9, 2013 | 05:06 PM
tosheto's Avatar
I have read many threads on the org of how people got rid of P0420 and P0430.
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
bigdogsteve
Jan 31, 2018 04:18 PM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
